CCV mod on 95 7.3 - Ford Powerstroke Diesel Forum
Old 12-28-2008, 10:13 AM
CCV mod on 95 7.3
help.
should i do it?
whats the benefit?
any harm from doing it?
thankyouuuu =]
Old 12-28-2008, 10:26 AM
BENEFITS...Keeps the oil out of the intake and turbo. If you gonna run an intercooler, it will keep oil out of the intercooler and that helps keeping boots from blowing off.
HARM... just to the ozone and your nose of your sensitive to funny smells. I just ran my hose to the rear of the frame and down the sway bar links. Some people use a catch can and a breather to keep from running hose along the frame and to catch any oil drips from it. I've had mine on for at least 2 years and no oil drips from the CCV hose.(lots of other drips to look at )
Old 12-28-2008, 11:03 AM
HAHA i know what you mean
now the ccv is that the little pvc elbow 90 degree that come off the driver valve cover and right into the intake tube????
if so how do i go about plugging that hole in the tube?
some direction if you could please
Old 01-01-2009, 09:54 PM
I'm gathering parts to do my DIY intake now. Part of my new setup will do away with the aluminum piece that has the CCV in it.
I bought the upgrade for my air intake hose (going into the turbo part # F81Z-9C681-BA which is for a 99-03 YM truck). I'll delete the aluminium center section and run a piece of 4" exhaust pipe (painted of course) straight into my new 6637ish filter. I'll do the CCV mod and install my new intake and listen to the new sounds of my turbo.
Enjoy!
Old 01-02-2009, 06:30 AM
send me pictures of it
Old 01-02-2009, 04:35 PM
I'm planning on taking pics and doing a small write up on it, afterwards. PM me in a couple of weeks for a reminder.
Old 01-16-2009, 01:11 AM
I did this, its not hard at all,not sure it really adds anything, just keeps oil and stuff from blowing back through your intake and turbo , that stuff will ruin intake boots!!!!!!!!
I did mine at the same time I did the 10k mod ,map sensor switch,and fpr shim and it only took maybe 5-10 mins. (i had to hunt down tools that got misplaced)
Old 01-17-2009, 04:17 AM
Powerstroke Junkie
There are no odors or mess if you do this mod correctly. Running a hose out the back isn't the correct way. Also doing this mod wrong can turn your stroker into a oil fountain, they are very sensitive to back pressure. Check your PM's for how to do this mod correctly. It is one of the mods I would perform on every 7.3!!
NCH
Old 01-18-2009, 06:13 AM
so to do this mod you delete the aluminum intake part that has the 2 holes in it (i think it has 2 holes? maby 1) and just clamp rubber hoses to the holes on the cc and run your hoses to where?
Old 01-18-2009, 06:20 AM
You just turn the plastic cover around and run the hose (make it longer) down behind the engine!
