Noob question--What am I going to regret? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-29-2014, 09:10 PM Thread Starter
sockwalker's Avatar
About a year ago, I bought a 1996 California CCLB, 4x4, auto, 4.10 posi, 6" skyjacker lift, 35 X 12.5 (18" wheels) Toyo MT's, stock motor with about 113K miles. It was a local truck, and I am familiar with the two previous owners. I only intend to drive it about 2,000 miles/year, and rarely will tow more than 3000-4000 pounds (at least for now). I am installing my 3" downpipe and 4" DiamondEye right now. Also have on hand gauges (EGT, Boost,Trans temp), TruCool tranny cooler & lines, TS6 chip with Wildman tunes for my stock California injectors, Boost fooler, DIY 6637 intake, HX crossover, and Banks intercooler ready to install in no particular order...I basically want a fun, reliable truck, with significant more power than stock. Money is something of an issue, but I have been putting some away for additional upgrades.
Sounds good so far, right...?
Well, now it has developed a major leak which appears to be spraying out the back of the fuel pump straight toward the rear of the engine (pi$$ing like a race horse, really). I have removed the fuel bowl and the three hoses which attach to the pump. I've read the threads on fuel pump removal and understand it can be a PITA.
I intend to remove the turbo and pedestal in order to more easily R&R the fuel pump. I know many will say go with e-fuel at this point, and I'm half inclined to do so. If I stick with stock fuel pump, I am going to replace all the typical O-rings and hoses down in the valley.
What am I going to regret not having done while I have the stock turbo/pedestal/fuel bowl & fuel pump removed. On my best day, I'm only an average mechanic
IF I had $3K to $4K to spend, what thing or what combination of things should I next be looking to install, and keeping in mind my average mechanical ability...should I:
1) New turbo (perhaps D66) with ebpv-delete pedestal
2) Stage 1 type injectors
3) E-Fuel
4) Something else?
Thanks for your thoughts, and thanks for all the advice I've been reading up to this point.
Save Clear Creek, and the Future of OHV
1996 California Truck
118,XXX miles
E4OD
Torreador Red
3" DP; 4" Exhaust
Tymar 6637; Boost Fooler; HX crossover
EBPV Delete Pedestal; EBPV Delete Housing
35"x12.5"x18" Toyo MT w/Gloss Black XD "Hoss" wheels.
Warn Premium manual hubs
On deck: 3 Gauge Pod; Banks IC; Tru-Cool; TW TS6 Chip
Someday: Injectors; HPOP; ???
sockwalker is offline
post #2 of 12 Old 04-30-2014, 05:35 AM
ja9788's Avatar
I would definitely do e-fuel. If you piece together your own kit you could probably save a decent amount of $$ to put back into injectors/turbo/etc.
Do you have a power goal in mind?
Also FYI you don't have to remove the turbo to R&R the fuel pump. I did mine with it in, took me roughly 2 hours to R&R everything. Just pay attention to not drop the plunger in the motor.
< Joel >
95 F350 SCLB 4x4
- WW2
- 3" DP to 4" Straight pipe
- IDM 140v Mod
- TS 6 Pos.
- K&N Intake
- Glowshifts....
ja9788 is offline
post #3 of 12 Old 04-30-2014, 08:22 AM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
when you pull the turbo rebuild it. I wouldn't do a D66 unless you do bigger injectors too (first), I would do e fuel. i did mine for ~$650 with a brand new motorcraft pump
the cali models have a damper on them, that requires the removal of the turbo.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 12 Old 04-30-2014, 03:34 PM Thread Starter
sockwalker's Avatar
I appreciate the replies.
My existing fuel pump has some pancake-shaped black disc on the top of it, which I think really inhibits access to the pump. Do all the trucks have this, or is this a "California Special"?
Sounds as if efuel is the preferred way to go.
If I do e-fuel, the fuel bowl, fuel pump, and FPR will then go away and never have to be dealt with again?
And as I understand, a D66 without bigger injectors will be useless. Does the D66 in combination with bigger injectors necessarily require efuel, or is efuel just a preferred method of fuel delivery regardless of the mods being installed?
Thanks again.
118,XXX miles
E4OD
Torreador Red
3" DP; 4" Exhaust
post #5 of 12 Old 04-30-2014, 03:39 PM
the baconator
Quoted: 146 Post(s)
Thanks again.
that is the damper
i say it requires e fuel, some don't necessarily agree with me. it definitely is a cleaner way to go
post #6 of 12 Old 05-02-2014, 11:59 AM
I would go with e-fuel. There is a guy out there (Mark Fugazzotto) who makes a kit to convert over. He makes the fuel block for on the engine and supplies it in a kit for 165. He also provides all the info for the rest of the pieces. I have 378 bucks in all of it. I bought a bosh pump but he uses a carter. Here is a video of the setup. I have not installed it yet but plan on it next month when I tear my truck down to redo it. He is a super nice guy. I have his contact info if you want it. He built this while putting a 7.3 in his 1958 chevy dump truck.
buggy5872 is offline
post #7 of 12 Old 05-03-2014, 10:40 AM Thread Starter
sockwalker's Avatar
Thanks for the video! That guy has a nice looking e-fuel kit.
Is yours already up and running with that kit?
118,XXX miles
E4OD
Torreador Red
3" DP; 4" Exhaust
post #8 of 12 Old 05-03-2014, 10:42 AM Thread Starter
sockwalker's Avatar
https://www.youtube.com/watch?v=hsS4-grcfrY
Oops--
I missed that. Disregard my question whether yours is already up and running.
118,XXX miles
E4OD
Torreador Red
3" DP; 4" Exhaust
post #9 of 12 Old 05-04-2014, 04:38 AM
I wish I had time right now to get mine on. I am putting up a 40x48 building right now and I have a machine shop I run as a side business that is out of control right now with orders.....hopefully I get a break soon so I can get to the truck.
post #10 of 12 Old 05-04-2014, 05:16 AM
rolsmojave3's Avatar
I've just went through this with my Cali truck. I went with MarkF's fuel lines, Carter fuel pump and 2 filters. I have under $400 in it with everything including the fuel line and good crimpable clamps. I used a Wicked Wheel 2 and EBPV delete and so far haven't purchased a chip. The truck has a noticable improvement in torque and it pulls much better.
1997 Ford F-350 4x4 SRW regular cab manual trans.
-4.10s, 315/75r16...getting a frame off restoration. Go fast stuff
1996 Ford F-350 4x4 SRW CCLB manual trans. CALI spec
-ATS intercooler, WW2 w/ 1.0 housing/EPBV delete, Comp 910s, SD Efuel, 3.55s, 315/75r16
2002 Ranger FX4 with manual transfer case and Alcoa's
rolsmojave3 is offline
The Following User Says Thank You to rolsmojave3 For This Useful Post:
sockwalker (07-30-2016)
