New turbo to upgrade stock TP38 - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-29-2014, 06:03 PM Thread Starter
JDoldnumber07's Avatar
Looking for a little bit of advice on a drop in replacement turbo for my 96' F-250. I currently run a stock TP38 with the 1.10 housing and an aftermarket intercooler, no EBPV (since i have a BD exhaust brake) a 3" DP and stock injectors. I am not looking for increased HP with a new turbo, i simply need a replacement since mine is starting to burn some oil, and i don't have time to send mine out for rebuild since i will be driving across country at the end of next month towing a 44' gooseneck trailer.
I would like to hear some opinions of the performance TP38 with a 1.0 housing and non-EBPV pedestal. Has anyone run this setup and can give me some feedback if i am making the right decision by going this route? Either way the pedestal will be replaced with the non-EBPV, but should i stick with a stock turbo with 1.10 housing or get the 1.0? Any help would be greatly appreciated!
Truck is a 96' F-250
ZF5 speed trans
intercooled
stock injectors
3" Downpipe
BD Exhaust brake
I usually don't see more than 900* towing the trailer loaded, and don't want to compromise my EGT's with a smaller housing. Truck is a daily driver 90% of the time with towing the gooseneck the rest of the time. No plans for bigger injectors or trying to make any high HP gains.
JDoldnumber07 is offline
post #2 of 14 Old 04-29-2014, 07:23 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Get a stock rebuild, and the 1.0 housing should increase spool and not much else, maybe even lower egt's in certain areas, but as far as hauling with it I'm not sure, should do fine with a slightly higher boost number, good luck
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 14 Old 04-29-2014, 07:40 PM Thread Starter
351 thanks for the reply. I just mostly wanted to make sure i wasn't going backwards with the 1.0 housing or putting myself into a position of requiring more supporting mods to accomodate this turbo. I know this isn't the typical looking for more horsepower turbo thread, but the stocker i have on now has made multiple cross country trips with the trailer and zero issues, it's just at the point of needing a rebuild.
If anyone else has experience to share please add your input! I am open to other drop in options too if there are any available for this setup and anyone has a better alternative. Thanks again
post #4 of 14 Old 04-29-2014, 07:44 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
If your not going to a bigger injector the stock turbo and 1.0 housing is good, but the d66 is drop in and better suited for bigger sticks tho
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 14 Old 04-30-2014, 09:26 AM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
i'm with kris, rebuild your stocker with a deleted pedistal and a 1.0 housing. riff raff used to be the best price on a 1.0 housing, and diesel orings has the rebuild kit (riff raff probably has it too)
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #6 of 14 Old 04-30-2014, 03:32 PM Thread Starter
Thank you I appreciate the replies. I went ahead and ordered the new turbo with 1.0 housing as well as the deleted pedestal. It should be here next week hopefully and I can see how it does compared to the 1.10 housing. Thanks again!
post #7 of 14 Old 04-30-2014, 03:36 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
You shouldn't be disappointed at all, and if you can spare it look into some custom tunes, they will make those hills and towing a breeze for ya
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 14 Old 04-30-2014, 04:12 PM Thread Starter
Custom tunes are in the future after I re-gear and replace my HPOP.. All things considered I am more than happy with how the truck handles and tows the trailer.. 246,200 miles and another 7,000 added in the next month
post #9 of 14 Old 04-30-2014, 08:07 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Re-gear? What ratio you running now? If your hpop is weak yes replace, if not keep the money for later jus in case bro, I'm north if 300k no issues yet other then cps lol
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 14 Old 05-01-2014, 06:55 AM Thread Starter
Right now I'm running 3.55's
I monitor HPOP psi and it doesn't need to be replaced, but would give me peace of mind to do anyway
