Electric Fuel Lines - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-29-2014, 08:29 AM Thread Starter
Electric Fuel Lines
Hey guys!! New to this site, and was wondering if there is anyone who just sells the lines for under the hood, i have the pump, filter heads and regulator. i can return the regulator and get the fuel bowl delete kit from swamps with regulator, but if there is anyway of getting the lines that would be prefered.
dieselcaveman73 is offline
post #2 of 4 Old 04-30-2014, 05:12 AM
ja9788's Avatar
I've never seen lines available separately. It probably wouldn't be that hard to make them using metal tubing or just use cover your hose with heat wrap.
You could always contact markfuga and purchase his regulated return kit as well. I believe they are going for $165 or so.
< Joel >
95 F350 SCLB 4x4
- WW2
- 3" DP to 4" Straight pipe
- IDM 140v Mod
- TS 6 Pos.
- K&N Intake
- Glowshifts....
ja9788 is offline
post #3 of 4 Old 05-13-2014, 07:33 PM
Nitro41's Avatar
Irate diesel has a nice regulated return setup. Have to pull the turbo n some atuff off the front of the engine to install it.
I got the budget kit from Mark, and he stripped it down for me so Im using a aeromotive adjustable regulator istead of the old fuel bowl parts. I havent installed it yet, but everything looks nice, and very well put together.
97 Single Cab F250 4x4 5 speed
Swapped D-60
Locked front and rear
160 sticks
Wildman Tunes
Hood Stack
OFE clutch
T500 HPOP
Linex rockers
35" MTR Kevlars
and a bunch more...
Nitro41 is offline
post #4 of 4 Old 05-14-2014, 06:40 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
You could leave the rear lines in and banjo block and get a female boss fitting from a hydraulic shop and then put a barbed hose fitting on it. Clamp and go. It's a -12 boss fitting if my mind serves me right
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
