HPOP to small??? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-28-2014, 03:09 PM Thread Starter
stroken96.'s Avatar
Unhappy HPOP to small???
I put my new injectors in a few weeks ago (160/80s) and now when my truck sits and i dont drive it for three days to a week it does not want to start it will puff white smoke and hit a few times and eventually take of after cranking on it for some time. I am still running the 15* HPOP right now and have my tunes set for it from TW. After it starts it run great until it sit for a few days. Is my pump to small to get the oil pumped up in the injectors? i just haven't got a 17* yet to upgrade it. Any thoughts on my problem?
stroken96. is offline
post #2 of 13 Old 04-28-2014, 04:05 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Sounds like it's draining back, but does it puff white after cranking a while or does it puff white instantly?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 13 Old 04-28-2014, 04:09 PM Thread Starter
stroken96.'s Avatar
It is right off the bat pretty much smells like fuel no oil (thank god)... i have had it start right up after a few days too. Could it be the IPR?
post #4 of 13 Old 04-28-2014, 04:56 PM Thread Starter
stroken96.'s Avatar
Ok so i just went and messed with my truck and i think its the glow plug relay. The volt meters not dropping when the wait to start light comes on, i hope that its whats causing the problem. It has been three or four years since i put the last one on.
post #5 of 13 Old 04-28-2014, 04:58 PM Thread Starter
stroken96.'s Avatar
I still want to upgrade to a 17* are they drop in and go using a SD HPOP or will i have to change anything?
post #6 of 13 Old 04-28-2014, 05:15 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
If you have a 96-97 it's drop in and go, and if it's rite off the bat, then sounds like you found the gpr or glow plugs is your culprit
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 13 Old 04-28-2014, 05:18 PM Thread Starter
stroken96.'s Avatar
Ok thanks for the info on the HPOP. I will put a new relay on it tomorrow and see what happens
post #8 of 13 Old 04-28-2014, 05:22 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
May want to check the glow plugs too
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 13 Old 04-28-2014, 05:24 PM Thread Starter
stroken96.'s Avatar
I ohm checked them when I had it apart to do the injectors
post #10 of 13 Old 04-28-2014, 08:41 PM
Quoted: 76 Post(s)
I did gpr and thought I was good but after I did the glow plugs too it was a huge difference in cold starts. No more white smoke or anything.
White95f250 is offline
