E-fuel for the RCLB 4x4 guys - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-19-2014, 10:28 AM Thread Starter
ja9788's Avatar
I've read most of the e-fuel threads a few times and still am struggling to come up with a decent spot to mount the setup. The transfer case and front shaft provide no room near the inside of the frame. Curious as to where other RCLB 4x4 have mounted their setup? Worst case I can fabricate something.
< Joel >
95 F350 SCLB 4x4
- WW2
- 3" DP to 4" Straight pipe
- IDM 140v Mod
- TS 6 Pos.
- K&N Intake
- Glowshifts....
ja9788 is offline
post #2 of 5 Old 04-20-2014, 06:27 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
I think terry knight mounted his on the outside of the frame rail and was gonna make a protective box to cover it prom damage but has never got to it or needed to
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #3 of 5 Old 04-20-2014, 07:11 AM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
I just put the pump on the frame and put my filter under the hood. Depending on the pump you use (I used a stock SD 7.3 pump) there is a ton of room
Trucks and parts............
kanuck15 is offline
post #4 of 5 Old 04-20-2014, 03:22 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
like frank said the pump is mounted to a plated welded to the outside of the frame rail, the filters are bolted to the cross member under the bed just behind the cab. tucked up nice and tight. i was going to build a cover for teh pump but haven't gotten around to it
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #5 of 5 Old 04-20-2014, 05:04 PM Thread Starter
ja9788's Avatar
terryknight your setup was the best option I came up with so I may go that route.
Thanks for the replies.
< Joel >
95 F350 SCLB 4x4
- WW2
- IDM 140v Mod
- TS 6 Pos.
- K&N Intake
- Glowshifts....
ja9788 is offline
