need some information... - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-14-2014, 04:29 AM Thread Starter
ToyoTundra11's Avatar
my buddy has a 7.3 i will be replacing the fuel lines under the turbo. but he also wants a new upgraded turbo and single shot injectors? i have no idea what he was talking about and would like to know my self. when doing this upgrade he was told he does not need his programmer to run it? what turbo and injectors do yal recommend...
ToyoTundra11 is offline
post #2 of 6 Old 04-14-2014, 08:16 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
He will need tunes to run the injectors efficiently. Without tunes the PCM will not know that the injectors are dumping more fuel than what it is programmed for. Also tunes will wake this truck up!
What year truck is this? Need truck info to answer your question appropriately.
As long as its a '94.5-97 and not a Cali model the truck will run single shots without a tune but...^^^. If this is a '99-03 Super Duty 7.3 it will not run singles without tunes. Drop in turbos for the old 7.3 engines are limited. BD Diesel makes a drop in and Beans Diesel makes the D66. There is a DIY D66 out there but I do not remember who sells it. Kits for bigger/better turbos can be had at places like Irate Diesel to get him into S style turbos or places like Ct Performance sell complete Holset model turbos.
From the '97 Cali truck through current Super Duties had multi-shot injectors. In general there is a quick pilot shot of fuel and then the power shot of fuel after the crankshaft turns a couple more degrees. These injectors quieted down the motors and made them more earth friendly emission wise as the engines would burn cleaner at idle (where most of these engines live if they are service trucks. From '94.5-97 Federal trucks they had single shot injectors. They are noisy dirty injectors while idling but more fuel efficient and powerful at cruising speeds.
Your buddy asking for "single-shots" doesn't mean anything to me. Our injectors go by flow and nozzle size rather then the Duramax's/Cummins's "horse power" sizes. Going by advertised "horse power" (similar to buying our injectors by Stage numbers) is silly. Our injectors are done by cc's and %. So the stock factory injector on a OBS 7.3L is 98cc/0%. This means that in 1000 firings of that injector (at full demand) it will move 98cc of fuel through a stock nozzle. Most of us jump to 150cc/160cc/180cc injectors. This is where the nozzles come in. You can cheat some extra power by going with a larger nozzle (20%/40%/60%/80%/100% over stock) to deliver the fuel faster at full demand then trying to push a larger amount of fuel through stock nozzles. The drawback is that under light demand, idling, or very easy cruising the larger nozzles run rougher then the stock nozzles. The fuel moving through bigger holes doesn't atomize very well.
Get us more info on the truck and what his plans for the truck are and we will be happy to offer opinions on available upgrades.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 6 Old 04-14-2014, 02:08 PM Thread Starter
dang, i posted in wrong section. its a 2000 model. it is basically his work truck and has 400,000 miles on it. wants more power out of it. he already has exhaust intake and custom program.
post #4 of 6 Old 04-14-2014, 02:37 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Then he should have his tunes re burned and run 160/0 (stage 1) and a 38r is the easiest upgrade for him
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 6 Old 04-18-2014, 04:07 PM
ok maybe im in the right spot my name is Ryan and i kinda new to the site I have a 97 reg cab long bed it has all the normal stuff gages and intake and exhaust im wanting to do a small build on it like stage 1's intercooler maybe swamps hvhf idm dont know much about those t500 hpop and chip the tranny has been modded i think its a john woodsman hpop i think if thats right please let me know what you think and ideas and i know my grammer suck lol thanks
ford_coleburner_97 is offline
post #6 of 6 Old 04-18-2014, 06:11 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Welcome to the org, john woods specializes in transmissions, what kind of modding does your Trans have? The t500 hpop has done very well for a lot of our members, what's your goals? What do you do with your rig daily and part time, that will help to give you the ins and outs of the parts your thinking of throwing at it and keeping it safe, reliable, and fun
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
