Wildman 6pos chip -no change - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-03-2014, 06:00 PM Thread Starter
Dzldust's Avatar
Ive had a Wildman 6 position chip for about 6 months now.
Its set at stock-economy-street-light tow-heavy tow and race
see no difference between stock and economy in boost-EGT's-fuel mileage or idle.
Street is a bump in power with same boost and egts as stock and economy.
Cant even tell if light tow does a thing or not.
Heavy tow and race -truck falls on its face
I get 15 -19 psi max boost letting the truck shift itself,If I hold gears manually I can see 22-25 psi.
cant get a direct shot at fitting to get an accurate fuel pressure reading at idle as of yet.Hate to send chip bak if nothings wrong with it.Could a fuel pressure issue be causing this lack of boost and performance?
I have a very small amount of soot on one of my up pipes and no audible hissing .Like I said it will build up to 25 psi of boost if it can rev out by manually shifting it .
Dzldust is offline
post #2 of 4 Old 04-03-2014, 06:21 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Where on the up pipes is the soot? I would honestly send it back for a reburn, did you clean the PCM well? Maybe your tunes are out of order? My tony chip was amazing although I couldn't tell a difference between light and heavy tow
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 4 Old 04-03-2014, 06:39 PM Thread Starter
Dzldust's Avatar
I followed the install instructions to the tee,small amount of soot near the top,about 1/2" has been the same since I got it 3 years ago,none on firewall or anywhere else on the pipes
Dzldust is offline
post #4 of 4 Old 04-03-2014, 08:26 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
May need up pipe gaskets, but sounds like chip may be faulty, send it back for a re burn
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
