D66 - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-30-2014, 09:00 PM Thread Starter
97Strokin''s Avatar
D66
So my bro bought his e99 back from insurance and we are going to do his set up on my 97 obs what all do i have to do besides his up pipes to put his d66 turbo intercooler and spider in? Do i need to change my pedestal? Easiest way to swap up pipes? Do i have to change manifolds? Will his ic pipes work?
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
97Strokin' is offline
post #2 of 11 Old 03-30-2014, 09:07 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Pipes won't work, you only need the turbo and y going into heads, and clamp, easiest way to remove up pipes is remove Trans, but several extensions worked for me
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 11 Old 03-31-2014, 03:18 AM Thread Starter
97Strokin''s Avatar
His up pipes will bolt to my manifold?
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
post #4 of 11 Old 03-31-2014, 08:03 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Your up pipes and manifold should bolt to his turbo iirc, but if not you will need his manifolds and up pipes
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 11 Old 03-31-2014, 10:12 AM Thread Starter
97Strokin''s Avatar
The sd uses clamps not bolts?
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
post #6 of 11 Old 03-31-2014, 12:48 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Ahh my bad, then get manifolds and up pipes, yours being a 97 I've heard hear say they match up fine, but also heard needing to swap the drivers side one, but let us know how it all works
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 11 Old 03-31-2014, 02:13 PM Thread Starter
97Strokin''s Avatar
Sounds like this could be interesting
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
post #8 of 11 Old 03-31-2014, 07:18 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Mite want to look into injectors too otherwise your going to have some lag, I'm not entirely sure the obs and e99 run same turbo pedistol btw
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 11 Old 03-31-2014, 08:48 PM Thread Starter
97Strokin''s Avatar
Ok what injectors will best compliment that turbo
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
post #10 of 11 Old 04-01-2014, 08:30 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Stage 2 (160/100's) maybe even 238/100 hybrids
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
