Make it handle - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-28-2014, 12:03 PM Thread Starter
GarrettFord's Avatar
Quoted: 5 Post(s)
Garage
Make it handle
I have a 95 with intake, down pipe, billet compressor wheel, TS 6 position chip, and gauges. Before I put anymore money into performance under the hood, I want the truck to handle better. Any advice on parts or where to buy them from would be greatly appreciated, thanks in advance!
96 4x4 F250 Xl Ext. Cab Long Bed 7.3 Powerstroke rebuilt 5 speed, rebuilt Front Axle, T500 HPOP, stage 1.5 injectors, 6-position chip from TS, quick spool housing, WW2, E-fuel, gauge pillar w pyro, boost, and fuel pressure
GarrettFord is offline
post #2 of 10 Old 03-28-2014, 12:34 PM
Quoted: 80 Post(s)
Feedback Score: 4 reviews
Don't mean to sound like a smart a$$ but it is a 6-7000lb truck so it will never handle like a mustang or corvette. I would check all bushings, ball joints, tie rod ends, sway bars and shocks. A good quality tire a little wider than stock might help you. Might consider replacing any rubber bushings with polyurethane.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #3 of 10 Old 03-28-2014, 03:49 PM Thread Starter
Quoted: 5 Post(s)
Garage
I know that, I don't want a auto cross truck, I really was talking more like sway bars, possibly tighter steering box, those type of things, but I'll check the poly bushings
post #4 of 10 Old 03-28-2014, 04:00 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Do you not have front and rear sway bars? Pull some from a Dually, lower it about an inch, wider tires, and stiffer springs, you should be able to hang pretty decent, what's the goal? My Dually has almost no body roll, but I have an extra set of rear tires
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 10 Old 03-28-2014, 10:42 PM Thread Starter
Quoted: 5 Post(s)
Garage
The goal is to make it more fun to drive from home to work and college. I love the power it makes, but it has a lot of body roll. I know it has a front sway bar, not sure about the back, I didn't know if some one made upgraded sway bars.
post #6 of 10 Old 03-29-2014, 08:44 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
There are aftermarket sway bars, some are huge. Hellwig sells a couple sets but some lift companies sell them too.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #7 of 10 Old 03-29-2014, 04:00 PM Thread Starter
Quoted: 5 Post(s)
Garage
Thanks, I'll have to look into that, what about tires, I know wider would be better but what about side wall stiffness?
post #8 of 10 Old 03-29-2014, 07:34 PM
I'm running Toyo AT IIs 35x12.50x20 on 20x10 inch rims. I had the front end completely rebuilt including new yukon hubs, and a new style Rancho steering stabilizer. I'm at stock F-350 height and it handles pretty good for a big truck. I will change out steering box and run some bilstein shocks to make it a bit better.
'97 XLT F-350 Crew Cab LB, 240,000 miles, 20x10 MB Rocker Rims, with TOYO 35x12.50x20, tool box, Swamps TS tuner, MBRP exhaust S&B Intake, Auto Meter gauges.
xjaddiction is offline
post #9 of 10 Old 04-02-2014, 11:38 AM
Stiffen up your suspension (stiffer springs, poly bushings, larger anti-sway bars ft & r, take all the slop out of steering box), lower the center of gravity (lower/shorter springs, remove body lift if any, blocks in the back if you must), increase the pavement contact patch (fit the widest wheel and tire combo that you can on the truck without being too short or too tall, and don't stick them outside of the wheelhouses), loose as much weight as possible and secure EVERYTHING that is staying (mount a bed box to the floor of bed by cab & don't just throw the stuff in it), get front to rear and side to side bias as even as possible (try to get the front end weight to equal the rear end weight, left side to equal right side, opposite corners to equal both side to side and front to back) this will be near impossible but try to get it close. If you have dual tanks, weigh truck w/ back full side empty, then w/ back & side full, then w/ back empty & side full to see how it effects the bias. Find a good truck scale shop and see if they will let you "play" on their scale or just buck up & pay for the use/time.
Brain's 97 Diesel is offline
post #10 of 10 Old 04-02-2014, 12:56 PM Thread Starter
Quoted: 5 Post(s)
Garage
Thanks for the run down, I'll post on what I decide to do
