How big injectors will the stock fuel selector valve maintain? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-26-2014, 05:00 PM Thread Starter
OBS Strokin's Avatar
I am looking at doing so e serious mods to my obs and am getting to the injectors and turbo part. How big injectors will the stock fuel selector valve maintain without hurting my power or making injectors useless. Looked at doing bronco swap but want some advice and input first. I read diesel power mag keeping up with the jones and it caught my attention. Thanks!
96 7.3 F350, 4x4, 5 speed, 6 inch skyjacker lift, 35 12.50 M/T Baja Atz, custom TW 6 pos, Banks Intercooler, BDP experimental fuel system, banks double shot water meth, Chromoly Push Rods, Swamps IDM Mod, 2nd Gen Wicked Wheel, Stage II AFE cold air intake, Down Piped 5 inch Diamond Eye exhaust, Gauges, ladder bars, upgrades drives lines yokes, on board air system, triple trumpet train horns, smoked head light and taillight housings, and 55watt HID kit!!
OBS Strokin is offline
post #2 of 11 Old 03-28-2014, 09:40 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Diesel Power's Mike McGlothlin was running 300/200 hybrids to high 500 hp with the selector.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 11 Old 03-28-2014, 11:29 AM Thread Starter
Ok cool. Just didn't want to build a furl system for nothing. I know bdp says you can buy theirs with a twin pump but will do my no good without swapping to a bronco tank or running just one tank..
post #4 of 11 Old 03-28-2014, 11:36 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Yeah, that kit is mostly for the Super Duty's with their giant single tanks. Unless you went semi-custom. Each tank is the same size more-or-less, run one pump to each head...
Matt
'97
-Stage II trans.
BigFuel is offline
post #5 of 11 Old 03-28-2014, 11:53 AM Thread Starter
Hmm idk. Got so many options. I just know I read dpm article on keeping up with the jones and they ran 300/200 and was having trouble....so I just wanted some opinions
post #6 of 11 Old 03-28-2014, 12:01 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Same guy as above
Matt
'97
-Stage II trans.
BigFuel is offline
post #7 of 11 Old 03-28-2014, 12:15 PM Thread Starter
Ah ok. So 300/200 maybe just a bit big then for selector valve. Somewhere I read in article you could put a bigger selector valve but I don't remember where that was at...
post #8 of 11 Old 03-28-2014, 03:33 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Here's the thing, sure you can put in a larger valve but then the pick-up tube is still 3/8" in the tank. Going for a bigger valve will get you a little longer of a blast of power but yo will still starve the engine from the tank. If you need the performance you get from 300/200, or bigger, then you are already looking at a custom setup. Pick your poison.
Matt
'97
-Stage II trans.
BigFuel is offline
post #9 of 11 Old 03-28-2014, 04:21 PM Thread Starter
Good point, think I will try to hunt me down a bronco tank. Most part I heard it bolts on. But I believe you have to leave selector valve hooked up to get a fuel gauge reading. Correct?
post #10 of 11 Old 03-28-2014, 04:31 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Not if that's the only tank you are going to run. Than you can just jump the two wires together. If you are going to use both tanks then grab a cheap 5 post relay and hook the switch's power to post 85, ground to post 86, gauge to post 30, and the front tank to 87a, and the rear to 87.
Matt
'97
-Stage II trans.
BigFuel is offline
