500hp question - Ford Powerstroke Diesel Forum
post #1 of 69 Old 03-25-2014, 04:58 AM Thread Starter
500hp question
Obs 7.3 5 speed I have all of this done
238/200% hybrid
S366 t4 kit
Sd intercooler
Adrenalin hoop
Dp tunes
Sb clutch hate it lol
4in down pipe to 5
Electric fuel pump and reg
I'm hitting 412Hp and 728 tq
I want 500 but I need some help I thought it would be more
hlzceller is offline
post #2 of 69 Old 03-25-2014, 06:03 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
What's your elevation?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 69 Old 03-25-2014, 06:07 AM
PSDTV21's Avatar
I think you need a bigger turbo
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
The Following User Says Thank You to PSDTV21 For This Useful Post:
Corey@CNCFAB (05-26-2014)
post #4 of 69 Old 03-25-2014, 06:10 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
With only 238/200's? Thought the s366 was good for those sticks? What boost/egt are you hitting btw?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 69 Old 03-25-2014, 06:14 AM
PSDTV21's Avatar
I personally think its a little on the small side for that size of injector
EDIT: What are the specs on the turbo?
-Tyler
1994.5
PSDTV21 is offline
post #6 of 69 Old 03-25-2014, 07:30 AM Thread Starter
1000 ft
Egt will hit well over 1600 at wot in fifth gear the sensor is in the manifold not dp
Boost 35psi on a oil pressure gauge
post #7 of 69 Old 03-25-2014, 10:31 AM Thread Starter
There r a lot of trucks one here with the same set up and there hitting a lot more hp than me I just want to know what else I need to do to get there
Will different dyno have different reading or are they all the same I just wondering if I need to go to a different dyno
post #8 of 69 Old 03-25-2014, 10:33 AM Thread Starter
Will water/meth put me above 500 or do I need to put a s467 to hit 500
post #9 of 69 Old 03-25-2014, 02:59 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Water meth will increase ya a bit, but 35psi is kinda low, I'd hit 32 stock sticks and charger on a Cali model, dyno's can read different from dyno to dyno
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 69 Old 03-25-2014, 03:35 PM
Hate stupid people
CloverLeafFarm's Avatar
Quoted: 128 Post(s)
turbo is to small for a 238/200. its not as durable as a 38r which is similar in CFM, but if your set on keeping that charger then you better ad a gate or its going to go bye bye.
when I had my e99 I ran the S300 based billet 66/74/1.10 with 160/80s I could hit 48 lbs.
Illiana Strokers DICtator
EFI Live tuned 6.7
CloverLeafFarm is offline
The Following User Says Thank You to CloverLeafFarm For This Useful Post:
hlzceller (03-28-2014)
