info on a dana 60 97 f250 swap - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-20-2014, 08:56 PM Thread Starter
hi everyone. i am looking to do a dana 60 front axle swap on my 97 f250. ive been doing research for a little bit it seems that i want to find one on a 92 to 97 f350. all i am looking for are problems that people have ran into. ive heard about the driveshafts from f250s being too long. seems like alot of problems. what would be the best way to get that thing up in there. thanks.
J7.3T is offline
post #2 of 5 Old 03-21-2014, 10:56 AM
dr.deere's Avatar
Quoted: 19 Post(s)
The front drive shaft needs to have an inch removed from it when you do a d60 swap. The easiest way to get everything you need is to find a wrecked f350. I was able to buy my axle complete with suspension brakes everything for 500. Spent 500 on gears to make it match truck. Another 300 on brakes and seals couple hundred on spring bushings and a couple hundred on shocks just because my shocks were shot. I then paid 200 to have driveline shortened to fit and spicer u joints put in it. I also put spicer joints in axles.
Sent from AutoGuide.com App
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #3 of 5 Old 03-24-2014, 05:42 PM
BR'sCrewCab's Avatar
There are some really good write ups available foe the d60 conversion. I used one from an org member named mjonesjr. Just use the search and you should see it. Very helpful.
96 F250 Crew Cab XLT
125,000 miles, Full Force Stage 1 Injectors, 4:10 rear, Dana 60 Swap, F350 Rear Lift Blocks, 325/60R18, 3" Down Pipe, 4" Exhaust, Tymar Intake, Aeoroforce Interceptor, DP Tuner (no start, stock, high idle, drive thru, 80 Eco, 60 Eco, 60 tow, 120 hp Race Tune), 7.3 Intercooler, 2.25 PMF RSK, V-Code Front Springs, B Code Rear Springs, Complete Alpine Audio System Upgrade, Tru-Cool Trans Cooler, Pro Comp 1069 18x9 Rims, John Woods Tow Master Transmission, Air Lift Air Bags
BR'sCrewCab is offline
post #4 of 5 Old 03-24-2014, 06:54 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
If yours is a 97 you do not need to shorten the drive shaft, it's a direct bolt in process and once you remove the TTB and slid the d60 under your going to think it was the simplest thing ever (it's easier then installing an Intercooler) you want an f350 front end hub to hub preferably, from 1986-1997, the 86-94 have slide pin calipers, the 95-97 have bolt on ones, but if the later you can use your current calipers, everything literally just goes in as it came out, have fun
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 5 Old 03-25-2014, 07:25 AM
95worker's Avatar
definitely give the d60s you look to buy a real good go over. I did not check anything but the gears and diff when I did my junkyard/craigslist shopping. I did the gears, and inner seal, bearings etc. and ball joints before I put it in. Later realized I installed an axle that needed one new spindle new spindle bearings, wheel bearings, short side axle (inner and outer) and ujoints!
In the end my dana 60 swap and rsk was one of the most expensive things I have done to this truck.
So don't be a dummy like me and try to source a axle that is in good shape.
Also, I cannot say enough about the SD springs and RSK. Best thing in the world! Dollar for dollar the best money I have spent on this pickup by far. Rides like an entirely different truck especially on bumpy terrain.
Also I got better turning radius with d60. Also no did not have to shorten my drive line. truck has a little lift to it from rsk so I don't know if that had any effect its, it only a couple inches so I doubt it.
Its a pretty strait forward swap and it will just feel awesome to see that junk twin beam in the scrap bin when your done!
Good luck
95 F250 xl - auto trans - Dana 60 front under sd springs and PMF rsk - rs9000 shocks - 285/75r16 GY Duratracs on eagle alloys -
Inside: 4 pod A-pillar with isspro boost, egt, and trans temp. , bt OBD reader and torque app. Also added tilt and cruise.
Under hood: 7.3psd, rw 160/30 injectors, PHP Hydra with php & gearhead tunes, afe intake/filter, 3" down pipe.
Coming soon: efuel, turbo, c.a. cooler, and bigger hpop.
95worker is offline
