Seeking education/experience and opinions - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-20-2014, 07:08 PM Thread Starter
joonbee's Avatar
Hey gang,
I know this is been beat up, but I want to get some advice/opinions on what I am planning.
Set on CXRacing intercooler (from them), a T500 (from Terminator), E-Fuel conversion (from Bean's) and a TS (from Gearhead). Unless there are some better bang for the buck suggestions.
Now what I am stuck on is injectors. I can get 160/stock for $850 or 160/80 for $1250 (from Warren). Apparently, I will gain 50hp with the 160/80, so my question is getting all these together as a package will it be worth the extra $400? Even going with the stocks it will be a huge difference, which is why I am wondering.
Anybody have a similar setup and what your results have been. I am looking for reliability, drivability and MPG. It is a daily driver and I tow a 11K lb 5th wheel camper. Also will my stock clutch be fine with the 160's?
Thanks for any feedback...
Jim
1994.5 Ford F350 CCLB, 7.3 with only 135k, 5spd. For now all stock except for a S&B CAI and a Diamond Eye 4" from the turbo back, 305/70/16 BFG A/T's on 16x12 MT Classic II,tonneau cover and added 3rd fuel tank/toolbox combo for an extra 48 gals
joonbee is offline
post #2 of 13 Old 03-20-2014, 07:49 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
DIY IC can save serious coin, I'm $140 in everything to Intercool my Dually and I Intercooled my f250 for $180, I have no experience with gear head or warren, heard great things about gear head and cxracing IC tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 13 Old 03-20-2014, 08:03 PM
Quoted: 83 Post(s)
Even with the 160/stock and supporting mods you will gain way more than 50hp. I haven't upgraded my hpop or fuel pump yet but I can tell you that with the mods I have it is a completely different truck especially when towing and I usually tow over 15K in mountainous terrain. A lot of guys will tell you to go with the bigger injectors and have them detuned for towing but I can tell you that the baby swamps I have do everything I need and then some.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #4 of 13 Old 03-21-2014, 08:03 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
^But I wish I had bought bigger.... OP you will be 1000's in the hole to do what I've done but sure as shti it really fun! I still tow heavy (12,000+) through mountains but I do have to watch my gauges. Since you have a '94.5 plan on your truck being down for a coupe weeks as Terminator doesn't have your HPOPs ( always be absolutely sure to tell people that you have a '94.5 as your front cover is different then a '96-03 7.3L ) in stock right now and needs your core to build from. I have the old Bean's kit, love it except the old pump they used to sell. Now it comes with a 044 so you'll be all set. It's pricier than a DIY system but it comes with a great mount for the system. Making your own is where people don't calculate their DIY kits price well. Time is money and most don't like to admit how long they researched parts, collected parts, created parts in those DIY write-ups. They have easily spent the same if not more then just buying the kit and installing it in a couple hours with no emergency parts runs.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #5 of 13 Old 03-21-2014, 01:40 PM
the baconator
terryknight's Avatar
Quoted: 149 Post(s)
i agree with matt on most things except that buying a kit will save you money. i did a DIY IC and DIY e fuel and spent somewhere between 6-700 on each using high quality parts. yes it did take time. you will need to upgrade your clutch so budget for that. injectors are on you and what you want the truck to do. matt and i both tow heavy and both run 160/10 with TW tunes.
call joey at Terminator he may have the pump in stock "if"you actually talk to him, he did when i bought mine, but matt is normally on top of his sh!t
jack i think the OP was saying there is a 50 horse difference between 160/stock and 160/80s
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #6 of 13 Old 03-21-2014, 03:18 PM
c69ss396's Avatar
I'm running baby swamps, D66 w/1.0 housing, swamps idm, terminator Hpop, swamps tunes. I finally started getting the stuff up for a dyi intercooler. I have no issues whats so ever (besides DOT) of hooking up to a 20k+ trailer...
My point is, take your time, do your homework. You get what you pay for and if you try and cut corners it will come back and bite you...
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #7 of 13 Old 03-21-2014, 04:14 PM Thread Starter
joonbee's Avatar
All excellent info so far. I am trying not to cut corners, but not just thro money out the window either.
I did look at baby swamps, but if I am correct they are basically a 150/stock and would cost me more than the 160's, which is why I went that way. Oh and I did mean that the 80's were an extra 50hp. I am leaning towards the 160/100, which was recommended by someone else and a couple of you are running that set up without issue.
I did talk to Joey, in person once and thru emails a few times. Has had some good advice and been very helpful.
I know I could save doing the DIY mods, but I don't have the time and I would rather have the kit from one place, which SHOULD make it reliable. A DIY setup would just get me killed by my wife when we broke down in the middle of nowhere going on vacation with the camper.
Someone mentioned expecting a clutch. Am I really gonna hurt my clutch or would that depend on how I was driving it? I don't want to have to deal with the cluth if I don't have too and I definitely don't want to have to start fixing internals.
Again excellent info and thanks for your time.
Anyone else wanna throw there .02 in?
Jim
joonbee is offline
post #8 of 13 Old 03-21-2014, 04:40 PM
the baconator
Quoted: 149 Post(s)
Originally Posted by joonbee View Post
Someone mentioned expecting a clutch. Am I really gonna hurt my clutch or would that depend on how I was driving it? I don't want to have to deal with the clutch if I don't have too and I definitely don't want to have to start fixing internals.
jim - it was me that mentioned the clutch. if you still have the DMF i would replace it anyway it is a ticking time bomb. my stock clutch starting with no extra power other than intake/exhaust and towing heavy. you can baby it around for a while, but it will go and then the wife will be mad
post #9 of 13 Old 03-21-2014, 05:39 PM Thread Starter
joonbee's Avatar
Thanks Terry. Pardon my ignorance, but what does DMF mean or stand for? Is there a way to tell if you have a stock clutch or not? I assume the truck has the stock clutch still because it only has 135k miles, but I believe the truck spent it's whole life pulling a 5th wheel trailer, because came with rails in the bed and "V" tailgate.
If not, any recommendations?
Thanks.
Jim
joonbee is offline
post #10 of 13 Old 03-21-2014, 07:21 PM
Quoted: 83 Post(s)
DMF stands for dual mass flywheel. If you have a single piece/solid flywheel you will have a rollover noise in the trans with the clutch pedal up in neutral.
Jack
322000 miles
