Another e-fuel swap w/ questions - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-13-2014, 09:49 AM Thread Starter
I have everything I need to do my e-fuel swap and have a pretty good idea of how everything is supposed to go together, but I have some questions. A friend of mine mentioned there's a possibility of getting air into the fuel lines. This seems like it could be a bad thing. If this is the case, are there ways to prevent it? I'm guessing the filters should be full with fuel. What's the best way to go about doing this? Also, after putting everything together, is there anything else that needs to be done before starting the truck?
- Dan
DChalue413 is offline
post #2 of 3 Old 03-14-2014, 08:40 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 43 Post(s)
Not much you can do to prevent getting air in the system. After you are all installed put a good sized battery charger on the truck and jump the fuel pump to run without the motor for a good 5 minutes. This will push all the air through as best as possible.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
The Following User Says Thank You to BigFuel For This Useful Post:
DChalue413 (03-14-2014)
post #3 of 3 Old 03-14-2014, 10:39 PM
sethc24's Avatar
In a regulated return setup even if you install the fuel filter dry all you need to do is turn the key on ( so the pump is on) and wait like 20-30 seconds and you can hear all the ear purging out into the rear fuel tank. Than she'll fire right up. No sweat.
1997 F-250 4x4. 5 speed
, 6637,exhaust,dp-tuner,dana 60, 33's
sethc24 is offline
