Gauges! - Ford Powerstroke Diesel Forum
post #1 of 21 Old 03-12-2014, 05:26 AM Thread Starter
Axlesteel's Avatar
Garage
Gauges!
Hi guys
I need some gauges and I was looking at the glowshifts but ive heard they suck. So my question is what did you guys do for gauges?? Autometer? And is there a kit where all of them are together like glowshifts? pyro, trans, and boost. Thanks
1997 F-250, SD Axle Swap Front and Rear, 4.10 LS, 20x10 -24mm, 35x12.50 Thuderers, E4OD W/ Shift Kit, Upgraded Torque Converter, Upgraded Trans Cooler, Ladder Bars By Me, TS-6, Baby Swamps, 3" DP to 4", 6637, PHP Tuning, Gauges, and A Lot of Lightbars!
Axlesteel is offline
post #2 of 21 Old 03-12-2014, 05:52 AM
hansel's Avatar
Quoted: 100 Post(s)
I got ISSPRO gauges from Diesel Manor, mine are EGT and transmission temp. he also sells a kit that has boost.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #3 of 21 Old 03-12-2014, 07:22 AM
joonbee's Avatar
I actually just installed my glowshift set on this truck. Have had about 3 sets and never an issue, but I know others have nightmare stories. Bang for the buck I guess I will keep using them until I have a nightmare.
Jim
1994.5 Ford F350 CCLB, 7.3 with only 135k, 5spd. For now all stock except for a S&B CAI and a Diamond Eye 4" from the turbo back, 305/70/16 BFG A/T's on 16x12 MT Classic II,tonneau cover and added 3rd fuel tank/toolbox combo for an extra 48 gals
joonbee is offline
post #4 of 21 Old 03-12-2014, 07:24 AM
Quoted: 4 Post(s)
Feedback Score: 5 reviews
Isspro's, IMO better than Autometers as the wiring of them is just to small and that makes for a harder install.
We carry Isspro's
CT Performance, Inc. is offline
post #5 of 21 Old 03-12-2014, 07:38 AM
Don't get glow shift I would pay the money and buy auto meter or Isspro. I bought the glow shift triple gauge package because I didn't want to spend more money on nicer gauges and I regret it. The quality of the glow shift gauges is really low especially the wiring they give you. The boost line is absolutely **** it literally feels like a straw you drink out of and breaks super easily. Later on I am def going to ditch the glow shifts and buy nicer ones...
1997 7.3 F250 CCSB 4X4
TS 6 position chip
3 inch dp to 4 inch to 8 inch stack
Tymar intake
114k miles
lynyrdskynyrd95 is offline
post #6 of 21 Old 03-12-2014, 09:10 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I ran auto meter, I run the dp tuner infinity now 7-14 perameters at once compared to the 6 I had
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 21 Old 03-12-2014, 09:18 AM
Raul@Stealth Automotive's Avatar
Isspro EV2's is where its at. i get more returns for Autometer brand gauges over any other gauges we carry....
Raul@Stealth Automotive is offline
post #8 of 21 Old 03-12-2014, 09:37 AM Thread Starter
Axlesteel's Avatar
Garage
Okay another question. How dangerous is it to not have gauges? I know you need them when you have heavily modified stuff but I dont have nothing right now. If i had a 3" dp, intake, and ww2 would I really need gauges? I dont pull very much and I dont race or anything.
post #9 of 21 Old 03-12-2014, 09:46 AM
Quoted: 4 Post(s)
Hundreds of thousands of these truck pull hard every day without gauges, that said its always best to know rather than hope.
post #10 of 21 Old 03-12-2014, 09:54 AM
BR'sCrewCab's Avatar
The digital gauges are a good option. I run the Aeroforce Interceptor and really like it. It's a clean looking gauge that I have mounted on my steering wheel column. I have it running boost and egt, and then when I tow, I have it cycle through boost, EGT, and Trans Temp. On warm up, I can watch the oil temp rise while I am warming it up on a cold start. I like it.
96 F250 Crew Cab XLT
125,000 miles, Full Force Stage 1 Injectors, 4:10 rear, Dana 60 Swap, F350 Rear Lift Blocks, 325/60R18, 3" Down Pipe, 4" Exhaust, Tymar Intake, Aeoroforce Interceptor, DP Tuner (no start, stock, high idle, drive thru, 80 Eco, 60 Eco, 60 tow, 120 hp Race Tune), 7.3 Intercooler, 2.25 PMF RSK, V-Code Front Springs, B Code Rear Springs, Complete Alpine Audio System Upgrade, Tru-Cool Trans Cooler, Pro Comp 1069 18x9 Rims, John Woods Tow Master Transmission, Air Lift Air Bags
BR'sCrewCab is offline
