What mods are next? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-27-2014, 07:21 AM Thread Starter
midavis97's Avatar
What mods are next?
I have a 97 f350 basic mods. Chip, Exhaust, Intake. What should the next mods I do be? In what order. Thanks. First post.
midavis97 is offline
post #2 of 10 Old 02-27-2014, 07:29 AM
Powerstroke_21's Avatar
What mods are next?
Gauges? After that it's just small stuff till you want to get into bigger injectors and a turbo. Auto or manual?
Edit: also what are your goals with truck and what do you plan on doing with it?
Sent from AutoGuide.com App
Jarrette
1999 F350 ecsb 4x4 130k miles.
Mbrp 5" exhaust
TS 6 pos chip with Gearhead tunes
Auto Meter CS Series gauges (boost, pyro, trans temp)
S&B Intake
Aftermarket wastegate controller
Mods to come:
Crank case vent
Hutch and harpoon mod (if not already done)
1997 F250 rclb 4x4 gasser
Going to do a 12v swap in it tho
Powerstroke_21 is offline
post #3 of 10 Old 02-27-2014, 08:04 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
IDM mod and CCV mod. Both cheap and easy.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 10 Old 02-27-2014, 08:15 AM Thread Starter
midavis97's Avatar
It is an an auto mild built. I have gauges just not installed. Im looking to get between 400 to 500hp. But to get there do you do e fuel first like there is so much I just kinda need a list in order. This truck does everything from hauling cattle hooking to a sled to running down the street. I just don't know where to start.
post #5 of 10 Old 02-28-2014, 05:36 PM
I would definitely say an intercooler, I just installed my Banks kit and it truly transformed my truck into a torque machine. I can't believe it is the same truck. it may be pricey but in my opinion the best bang for the buck so far....
okietom is offline
post #6 of 10 Old 03-01-2014, 06:33 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
500 will need a built trans to live. Big jump from 400 to 500hp as far as what needs to be done. It starts getting expensive.
CT Performance, Inc. is offline
post #7 of 10 Old 03-02-2014, 10:53 AM Thread Starter
midavis97's Avatar
Im single in the Military my truck is my baby and the only thing I have to spend my money on.
post #8 of 10 Old 03-03-2014, 07:04 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
What branch, thanks for your service
Intercooler, Efuel, hpop, injectors, custom tuning, hook up gauges, and see where you land
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 10 Old 03-17-2014, 12:46 PM Thread Starter
midavis97's Avatar
The worlds greatest Navy. Thanks for the help.
post #10 of 10 Old 03-18-2014, 12:50 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
No problem, and let us know where you decide to start, I have a friend in the naval men's department (Marines) and has a reg cab 97 and it really is completely hooked up, and it's immaculate
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
