Just installed my baby swamps and tunes :-) - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-25-2014, 06:04 PM Thread Starter
speedracer7c's Avatar
All I can say is why didn't I do this sooner! Unbelievable difference in power over the stock 300k mile injectors. While I was in there I did valve cover gaskets UVCH's and glow plugs. The truck runs so smooth and is an animal!
Im really happy with the swamps tunes low smoke and egts are perfect. I went from barely making 15 psi boost to easily making 30. My hpop seems fine atm no cel at wot. Fuel pressure at idle is 60psi. Overall im pumped.
97 F350 Reg cab XLT 7.3, ZF5 Swap, Diamond eye 4" turbo back,Riffraff 6637, Deleted pedestal and outlet, riffraff billet wheel, Baby Swamps, Ts 6 pos with swamps tunes Glow shift triple gauge pod
340k miles and kicking!
2016 F-250 Supercab 6.7
speedracer7c is offline
post #2 of 9 Old 02-26-2014, 06:38 AM
That is awesome to hear. My truck is going to their shop in a couple of weeks for full work up. I can't wait to drive it after that.
'97 XLT F-350 Crew Cab LB, 240,000 miles, 20x10 MB Rocker Rims, with TOYO 35x12.50x20, tool box, Swamps TS tuner, MBRP exhaust S&B Intake, Auto Meter gauges.
xjaddiction is offline
post #3 of 9 Old 02-26-2014, 07:13 AM
Quoted: 74 Post(s)
Hearing stuff like this keeps pushing my closer and closer to doing mine. I'm just doing the basics and still gaining more power. With mine being tuned I keep getting more and more out of it with replacing sensors and giving it some TLC.
White95f250 is offline
post #4 of 9 Old 02-26-2014, 07:30 AM
ja9788's Avatar
I've been on the fence about getting these and I think I might spring on them now. I assume you had stock TS tunes before swamps, how do they compare?
< Joel >
95 F350 SCLB 4x4
- WW2
- 3" DP to 4" Straight pipe
- IDM 140v Mod
- TS 6 Pos.
- K&N Intake
- Glowshifts....
ja9788 is offline
post #5 of 9 Old 02-26-2014, 09:38 AM Thread Starter
No I had a superchips micro tuner (garbage) The difference in the truck is night and day, literally no comparison at all. Im very happy with the swamps tunes, they are all clean except the last tune which is an all out tune. I highly highly recommend this upgrade to anyone whos on the fence about it. Even with stock fuel turbo and hpop im EXTREMELY happy with the results.
post #6 of 9 Old 02-26-2014, 12:13 PM
Quoted: 80 Post(s)
Feedback Score: 4 reviews
I'm extremely happy with my baby swamps. I have a Dp f5 chip instead of swamps tunes because of the shifting I wanted for towing on extreme mountain grades but after the injector install and then custom chip install it is a completely different truck. The funny thing is a buddy of mine is using my gold superchip until he gets the money for a custom chip and had a (iirc) hypermax program flashed in and says the superchip made his like a totally different truck.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #7 of 9 Old 02-26-2014, 01:41 PM Thread Starter
your buddy is in for a pleasant surprise when he makes the change! I feel confident that my truck will make some of the local guys who think their trucks all that look silly. Rusted fenders and all!
post #8 of 9 Old 06-29-2015, 10:44 PM
Jessiah's Avatar
I just installed the baby swamps. I ran the truck to besure the installation went well. After it quit smoking an bucking around, wow the truck idled smoother and quiter. I installed the chip and well it idles ruff and I have a check engine light. I plan on pulling the chip and recleaning the contacts. Looking forward to the results.
96 F250 7.3l 4x4
3" down pipe/ 4" exhaust/ 6" tip
cat removed, afe air intake
Mag-Tec trans & diff. covers
All Amsoil fluids/ dual filter with bypass
Autometer piller gauges
Dana 60/ 3" sky Shackle reversal/ Bilstine shocks
skyjacker springs, Air bags
203 thermostate, 1500 watt block heater
Banks Intercooler
360 turbo bebuild, 1" housing, WW2, Below up pipes, EBPV delete
Baby Swamp injectors / TS 6 pos. Chip
Jessiah is offline
post #9 of 9 Old 08-01-2015, 05:11 PM Thread Starter
did you ever finish your install and get rid of your cel?
