PhP Gryphon cts - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-03-2014, 06:44 PM Thread Starter
PhP Gryphon cts
I am looking into getting the PhP Gryphon cts programmer for my 2000 F250. Someone told me I needed exhaust before I use a programmer, is this true? Is there a difference between the programmer and chip. I liked the CTS because I could use it to view egt, boost and trans temp. any help would be appreciated
jlegan is offline
post #2 of 3 Old 02-04-2014, 09:09 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
PHP could load "stock" tunes to the programmer instead of the "Modified" tunes most people would buy. Your diesel would be much happier with a bigger exhaust and intake first though. Getting the tunes last just means that you wouldn't have to send it back later to have it re-burned to the new mods.
Difference between a programmer and a chip is how it effects the PCM. A chip is a piggyback device that takes the signals from the sensors and the PCM and "adjusts" them on the fly to suit your driving needs as well as giving you up to 15 different "tunes" at the ready depending on the job at hand. A programmer flashes the PCM with it's program over the factories program, replacing it. This can take s e v e r a l minutes to do. The chip is as fast as let off go pedal, click the knob, step on go pedal. The big advantage of the programmer is that they have a screen that lets you monitor the sensors. Chips can't do that.
As a third option DP has the Infinity programmer that also activates a chip. All the monitoring ability (more actually as the CTS only sees so much, and the infinity you can add sensors to the programmer to see more) of a programmer with the speed of a chip. The Infinity is design and programmed to your truck. All the PIDs that Ford monitors are available on the Infinity
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 3 Old 02-17-2014, 10:28 AM
Sean@php's Avatar
Our CTS is offered with canned calibrations, but unfortunately we are no longer able to offer custom calibrations for them. Our Hydra chip offers 17 positions and you have the availability to switch on the fly. Alot of people really enjoy using the CTS system as digital gauges, which is why we are currently offering a bundle price when you purchase the CTS and Hydra together. If you Have any questions feel free to call us or email me at Sean@phptune.com
Sean@php is offline
