What to do next? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 02-01-2014, 08:18 AM Thread Starter
GarrettFord's Avatar
Quoted: 5 Post(s)
Garage
What to do next?
I have a 95 7.3 psd with a k and n intake, TS performance 6 pos chip, and a billet wicked wheel. I'm currently in the process of getting a set of gauges and was wondering what I should upgrade next?
96 4x4 F250 Xl Ext. Cab Long Bed 7.3 Powerstroke rebuilt 5 speed, rebuilt Front Axle, T500 HPOP, stage 1.5 injectors, 6-position chip from TS, quick spool housing, WW2, E-fuel, gauge pillar w pyro, boost, and fuel pressure
GarrettFord is offline
post #2 of 20 Old 02-01-2014, 08:38 AM
Quoted: 48 Post(s)
DITCH the K&N. Too much dust, not enough air. You can use the hardware, and swap in a 6637. Downpipe would be the next bolt-on. Or full exhaust. Complements the intake (breathe in, breathe out...).
From there, you're looking at injectors, fuel, HPOP and internals.
madpogue is offline
post #3 of 20 Old 02-01-2014, 09:45 AM Thread Starter
Quoted: 5 Post(s)
Garage
What do you mean by too much dust? Have you had problems with them letting dirt past? And yeah I was thinking down pipe and then stage one's
post #4 of 20 Old 02-01-2014, 10:21 AM
Quoted: 82 Post(s)
Feedback Score: 4 reviews
Take that K&N filter and hold it up to a light, see all those pores that the light is shining through. Well those pores let a lot of fine dust particles through the media and will damage that nice wicked wheel and your engine. These engines pump a lot of air through them and when the turbo starts winding up that is even more air flow. With the amount of dirt I've seen go through the K&Ns even new or well cared for I will not use them on anything I own.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #5 of 20 Old 02-01-2014, 11:40 AM Thread Starter
Quoted: 5 Post(s)
Garage
Well I didn't realize that, thanks for the heads up, so what would you suggest to replace it with?
post #6 of 20 Old 02-01-2014, 07:54 PM
Quoted: 82 Post(s)
As brought up in the second post, a 6637 filter. It should clamp on right in place of the K&N filter
Jack
322000 miles
post #7 of 20 Old 02-01-2014, 08:23 PM Thread Starter
Quoted: 5 Post(s)
Garage
How is the flow on those filters? and do the auto meter gauges come with all the wiring and probes/sending units with them?
post #8 of 20 Old 02-02-2014, 12:23 AM
m j
will outflow the kn hands down and will actually clean the dust out of the air charge
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
post #9 of 20 Old 02-02-2014, 03:36 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
New the auto meters should be complete
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #10 of 20 Old 02-03-2014, 07:27 AM Thread Starter
Quoted: 5 Post(s)
Garage
Ok cool, thanks for all the help! So does anyone have suggestions on where I could possibly put a trans temp sensor in my automatic?
