What to get first - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-28-2014, 08:05 AM Thread Starter
What to get first
So I have a 95 powerstroke. 3 inch straight pipe to a 5 inch stack and a boost gauge installed. I plan to get a mbrp downpipe and a trans temp and egt along with a ts 6 position chip. I have the money for the chip right now and was planning on ordering it. My question is if I can get away with not having an egt for a month or so with the ts chip or if I should buy trans temp and egt first?
Pbballer33 is offline
post #2 of 9 Old 01-28-2014, 08:25 AM
dr.deere's Avatar
Quoted: 19 Post(s)
You can always run the chip on a low horsepower setting or stock until you get the egt I wouldn't recommend towing or anything like that with the chip on without it I have went over 1200 in my egt gauge with no chip towing heavy and had to back out of the throttle.
Sent from AutoGuide.com App
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #3 of 9 Old 01-28-2014, 08:33 AM
BR'sCrewCab's Avatar
Get the gauges first. Once you get the chip you will be tempted to test out the new power, and with no way to monitor it, you will be flying blind.
96 F250 Crew Cab XLT
125,000 miles, Full Force Stage 1 Injectors, 4:10 rear, Dana 60 Swap, F350 Rear Lift Blocks, 325/60R18, 3" Down Pipe, 4" Exhaust, Tymar Intake, Aeoroforce Interceptor, DP Tuner (no start, stock, high idle, drive thru, 80 Eco, 60 Eco, 60 tow, 120 hp Race Tune), 7.3 Intercooler, 2.25 PMF RSK, V-Code Front Springs, B Code Rear Springs, Complete Alpine Audio System Upgrade, Tru-Cool Trans Cooler, Pro Comp 1069 18x9 Rims, John Woods Tow Master Transmission, Air Lift Air Bags
BR'sCrewCab is offline
post #4 of 9 Old 01-28-2014, 02:46 PM
d7es3l's Avatar
I am assuming you're eager to get that extra horsepower, so I say go with the chip first! On a stock injectored truck you should be okay on egt temps. Although I wouldn't wait too long after that to get an egt gauge to see what your truck is doing.
d7es3l is offline
post #5 of 9 Old 01-28-2014, 03:43 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
get the DownPipe first, then gauges. don't go with the MBRP the fitment is poor at best. diamond eye is better choice
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #6 of 9 Old 01-30-2014, 06:37 AM Thread Starter
So I just got a wicked good deal on the guages. Someone local had glowshift 7 color tinted gauges he sold to me for $50. egt, boost, trans. The egt probe didn't come with it. I looked on glow shift's website and its $50 for a new one. When i look on ebay there are some that come up for like $20 and they look the same. What do you guys think? will it work or should I just buy the one direct from glow shift?
post #7 of 9 Old 01-30-2014, 06:45 AM
Raul@Stealth Automotive's Avatar
honestly they are prob the same... they are both made overseas.... as for the exhaust i would go with a diamond eye kit and a custom tuned chip... i like TW, php or DP.
Raul@Stealth Automotive is offline
The Following User Says Thank You to Raul@Stealth Automotive For This Useful Post:
Pbballer33 (01-30-2014)
post #8 of 9 Old 01-30-2014, 07:09 AM
d7es3l's Avatar
Right on. Seems like a good deal. Just be careful of inaccurate gauge readings with the glow shifts. So when you get then installed, come back here and tell is what your readings are.
d7es3l is offline
post #9 of 9 Old 01-31-2014, 07:13 AM
Quoted: 74 Post(s)
What do you have for an intake? Do the intake and DP and that'll make a good difference then do the tuner. The DP and intake made the biggest difference in my mpg's.
White95f250 is offline
