I just put in my own homemade 4" exhaust... - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-27-2014, 03:40 PM Thread Starter
jimhuntertx's Avatar
Quoted: 3 Post(s)
Send a message via Skype™ to jimhuntertx
Talking I just put in my own homemade 4" exhaust...
I just today put in a home made 4" exhaust system. I took out the stock exhaust on my 97 and put in a Diamond eye 3" to 4" test pipe then took a section of straight pipe straight back to where the frame kicks up for the bed then put a 45 degree bend and another section of 4" pipe and exit it in front of the tire. I plan on finishing the system with a 5" stainless tip. The old girl really like the new exhaust, and boy you can really hear that turbo now. I will post pics once I get the tip on.
97 F-250 2wd Extended Cab Longbox, Pyro,boost and trans temp guage, 3" down pipe,
New E4OD Trans, TS 6 chip
Banks TransComander, 4" to dual 4" Bullydog 4" Dual Exahust , DIY Tymar intake w/ K&N Filter, Shimmed FPR
jimhuntertx is offline
post #2 of 5 Old 01-30-2014, 06:29 PM Thread Starter
Quoted: 3 Post(s)
Wink Here are the pics I promised
Here they are !!!
Jim
ID:	235858   Click image for larger version
ID:	235866   Click image for larger version
post #3 of 5 Old 01-31-2014, 07:15 AM
Quoted: 74 Post(s)
Nice, kinda looks like mine but i've switched exhaust set ups so many times it's got a few reweld spots. Tip is a good touch I need to add.
White95f250 is offline
post #4 of 5 Old 01-31-2014, 06:13 PM Thread Starter
Quoted: 3 Post(s)
Thanks you. I just wanted to do something different and didn't want to spend a fortune doing it.
Jim
post #5 of 5 Old 01-31-2014, 07:34 PM
JJFLASH's Avatar
Quoted: 111 Post(s)
Looks good there Jim. I was planning on adding a tip to mine but just never really got around to it.
-JJ-
Mine - 94.5 F250 ZF5: Basics w/a few extras, DIY bumper, steps and exhaust, AFEII, D60, PMF 2.25 RSK, V-codes
Hers - 04 GM 2500 CCSB 4x4: LB7, EFI Live by KW, 2" Lift, MBRP 4" dp back
RIP 15/08/23- 98 GM 1500 ECSB 4x4: 6.5, straight pipe, K+N filter, 495km w/original pump, trans & t-case
JJFLASH is offline
