200cc Rosewood Injectors, TP38 Turbo Thruster 2, Ts 6 position chip - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By terryknight
post #1 of 6 Old 01-13-2014, 12:28 PM Thread Starter
Possum92's Avatar
About to do some upgrades to my 97 obs thinking of 200cc rosewood injectors, tp38 turbo and meth injection with a airdog fuel system hoping to break 400 hp any suggestions out there ?
Possum92 is offline
post #2 of 6 Old 01-13-2014, 12:31 PM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
why re-invent the wheel on a 15+ year old truck?
1st intercooled
2nd t3/t4 is better
3rd upgrade the hpo system?
4th trans?
5th meth is bad , water only is better
6th tunning?
7th figure out what google is
if these are addresed already then go for it. BTW its gonna take 10K ish to hit 400hp
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #3 of 6 Old 01-13-2014, 12:35 PM Thread Starter
Possum92's Avatar
ment to say honey badger hpop tony wildman 6 position chip for tuning
Possum92 is offline
post #4 of 6 Old 01-13-2014, 12:55 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
i disagree with this unless you are including a fully built trans
personally i would go stage 2s (160/100) injectors ~$1200
T500 ~ $450
DIY intercooler ~ $700 (can be cheaper if you find the right deals)
DIY Electric fuel ~ $650 (can be cheaper if you find the right deals)
D66 ~ $1200
Tymar Intake ~ $150
4" turbo back exhaust ~ $300
TS chip w/custom tunes ~ $400
Gauges ~ $350
~ $4100
Built auto (BTS, JW) ~ $6000
5 Speed SMF clutch ~ $950
should put you around 425-450
Possum92 likes this.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #5 of 6 Old 01-13-2014, 01:01 PM Thread Starter
Possum92's Avatar
thanks alot that is less than what i priced out every thing i am kinda new to the diesel seen just got ride of my 04 f150 im in love with my 97 even tho she has alot of miles on her
Possum92 is offline
post #6 of 6 Old 01-22-2014, 04:05 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Do your self a favor and take a compression test on all cylinders b4 u throw cash at her.
If your getting his 200/30 I hectors your stock HPOP will be just fine as that is the purpose of those injectors. They take very little HPO to drive them. If yours was shot I'd got with the t500. No need for a honey badger
The Beans D-66 has been a proven turbo while the thruster has not that I've heard of. If u want a better turbo then that look into a t4 or t4i turbo kit with some sort of 66mm Frame, s366, qssb, h2e, or even a SD up pipe and intake set up with a 38r which spools very well.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
