Leveling a 97' 2wd - Ford Powerstroke Diesel Forum
post #1 of 14 Old 01-12-2014, 06:02 PM Thread Starter
MWilbur516's Avatar
Leveling a 97' 2wd
I'm wanting to level the front of my 97' F250. It's a 2wd ecsb model. My issue is finding a kit for this truck. Being its a coil spring front end, I know it can be leveled using spring spacers. I'm just having trouble find a set of spacers. Diesel Power Magazine leveled the front of their Project 300 using a Daystar kit, but they don't give a part number. I assume its this kit.
Daystar? - Driven by Design
This is for the 99+ 2wd trucks, but its all I can find that's close. Anybody know anything about this? Would the stud extentions have the same thread? I've tried to do my homework on this, but honestly there isn't much out there.
Sent from AutoGuide.com App
Matt | 2006 F250 XL FX4 6.0L 485RWHP and 968RWlbs-ft
Vision Diesel Performance503-487-6074
BULLET PROOF DIESEL 1-888-967-6653
TWISTED TRANSMISSION Contact me for a quote on a trans with the best warranty in the business.
MWilbur516 is offline
post #2 of 14 Old 01-13-2014, 09:02 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
I'm been told that there is just a little but is grinding to the block to get it to fit our cups but I have not installed these in a non-SD before. When I went looking for a leveling kit I also noticed that my springs were sagging anyway. Replaced the coils with 1000# overload coils and gained an easy inch by itself. I didn't feel that I needed the spacers after that. Be warned that lifting the front higher than factory intended will usually require you to replace your ball joints with ones with more of an offset. If this is something you can't do yourself be ready to pay out the azz for it to be done.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 14 Old 01-30-2014, 04:18 PM
redogg322's Avatar
Send a message via AIM to redogg322
I was thinking about giving these a shot
00 f-350 4 door long bed 4X4
Nitto Terra Grapplers
7.3 4" downpipe with 5 " Exhaust Stacks
[EMAIL="
redogg322 is offline
post #4 of 14 Old 01-30-2014, 07:58 PM
Garage
I replaced my front springs with supercoils and gained the height I needed.
http://supersprings.com/supercoils_fitchart.asp[/URL]
brianpearce is offline
post #5 of 14 Old 01-30-2014, 09:36 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Anymore detail on that or a good link? They are from where I am here in ga
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 14 Old 01-31-2014, 06:09 AM
redogg322's Avatar
Here is the item number 121163426572
[EMAIL="
post #7 of 14 Old 01-31-2014, 06:26 AM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 18 Post(s)
Feedback Score: 12 reviews
Just get a hanger and shackle kit to drop the rear a few Inches, or take out the blocks between axle and leaf springs.
2017 f250 platinum
Bone stock until warranty expires!
mts678 is offline
post #8 of 14 Old 01-31-2014, 07:22 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
because going down is for cars and chicks
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #9 of 14 Old 01-31-2014, 08:04 AM
mts678's Avatar
Quoted: 18 Post(s)
Mmm ok. 2wd's look better lowered about 2 inches. Plus he wouldn't have to fork out more money to realign the front end.
OP- don't use an aluminum spacer if you level the front. Rougher ride. Get the daystar kit.
2017 f250 platinum
mts678 is offline
post #10 of 14 Old 01-31-2014, 08:18 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
Sorry, more seriously our 2WD's don't have blocks (they sit right on the saddles) And the longer hangers rub on the bodies. Also with longer hangers you lower your weight rating as well as start to require custom suspention mods other then using bolt on mods designed for the stock setup. Our best option is to go up in the front if we want a leveled truck.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
