Injector module mod - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-11-2014, 05:45 PM Thread Starter
Injector module mod
Okay, new to everything diesel. I've been urged to put some sort of resistors into the injector module that adds power and fuel mileage..
Before I briefly looked up resistor Mods, and I never gathered I'd they were good things or not
austinlibke is offline
post #2 of 11 Old 01-11-2014, 08:38 PM
Quoted: 82 Post(s)
Feedback Score: 4 reviews
I've done the mod on 5 idms and they all are working well. Btw the mod doesn't really increase mileage, driving style is what dictates that.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #3 of 11 Old 01-11-2014, 08:44 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Look up the 140v idm mod, lots of happy customers, although there have been a few who have messed up an idm
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 11 Old 01-11-2014, 09:11 PM Thread Starter
I was just wondering because the person who was urging has only done it on a super duty
post #5 of 11 Old 01-13-2014, 10:08 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
Not a hard job. If it was a 7.3L SD than what he was doing is pretty much what you'll be doing. You do have to get the right resistor for your IDM, his resistors won't work in yours.
DIY - IDM mod (Injector Mod) - How to w/ lots of pics
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #6 of 11 Old 01-13-2014, 10:29 AM Thread Starter
That's what I was thinking, thanks for the confirmation
post #7 of 11 Old 03-03-2014, 09:02 AM
mjones3586's Avatar
bout to do this mod is the resistor the same for all obs or do i need to go out nd check my voltage and then get resistor of my own size. Just figured I would ask before this .29 breaks my bank haha naw just checking and asking so i dont blow a idm
"Diesel Head and Machinist"
4 inch lift o 36"s
3"DP to 7" Mitre Cut Stacks no cat/muffler
mjones3586 is offline
post #8 of 11 Old 03-03-2014, 09:04 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
It is the same for all OBS trucks but it's not entirely likely that you still have the stock IDM.
Matt
'97
-Stage II trans.
BigFuel is offline
post #9 of 11 Old 03-03-2014, 09:33 AM
mjones3586's Avatar
right i understand that i was bored today since we got hit with ice and snow i couldnt make it to work. Been reading up on mods for my truck and its too cold. I have to get in there anyways to unhook my EBPV anyways
4 inch lift o 36"s
post #10 of 11 Old 03-03-2014, 10:40 AM
I would get the Swamps HVHF IDM has worked great for me in the last year.
00 Excursion 7.3 (1.0 Ex. hsng., 3.5" downpipe, Aero Muffler, Banks WG, Banks Comp. Wheel, AFE Stage 2 Air intake, HPX, IAH delete, DP- Tuner F6, Riffraff Boost Fooler, Melling Oil Pump), Fuel lab 41402 pump and regulator, fuel bowl delete, 910 Comp Springs/Shims, DI Pushrods, Swamps HVHF IDM, SRP 1.1 HPOP Dieselsite trans and coolant filter, 203* thermostat, Sonnax valve 0.427 and tricumulator springs, Lift, MM Hubs, 35's and 3.73s, 08 diff cover, Hellwig rr. bar
326RWHP @ 731RWTQ.
572ysc is offline
