Originally Posted by PSD0389
Hey guys I got the funds so Im gonna do some stage 1 injectors in my truck from DIY injectors. Ive helped do injectors in cummins before but never a powerstroke and was looking over the instructions and had a couple questions I was hoping could be answered. Hopefully these dont sound like dumb questions. I noticed the HPOP reservoir and crankcase should be drained. where is the HPOP and crankcase drain located?
Also I know you need to remove the oil galley plugs and it says one of the plugs on the outside of the valve covers on the oil rail should be removed for air to go in, where is that located?
I noticed also to use a large syringe and tubing to go down the injector bore and into the cylinder and remove all the fluid then crank the engine a couple times after to remove the rest. How do I hand crank the engine? and will that just push the rest of the fluid out the bore and I clean it up with a lint free towel?
I also noticed that with the glow plugs out and injectors back in I should turn the engine over to get the rest of the fluids out of the cylinder. Do I hook the wire harnesses back up to the injectors then hook up the VC gasket to the harness running to the solenoid before doing this?
Also with cranking the engine as said above do I leave the oil galley plugs out as well and replace them once oil is coming out of them. Then put the valve covers back on and turn it over?
Im sorry for all the questions Im just trying to get it all straightened out, thanks for the help
I used my handy-dandy hanes manual for injector removal tips. They are very vice to have around.
Remove the valve covers and find the galley plugs. Let the oil drain before removing any injectors.
The syringe is a good idea. After installing the injectors, replace the galley plugs, remove the glow plugs and crank the engine over a few times to blow the oil out. I shorted the starter relay to spin the engine without it fueling.
This is all I did when I did mine, but many people have other tips and hints also.
Good luck and enjoy your new injectors!
