New to psd's.... - Ford Powerstroke Diesel Forum
post #1 of 20 Old 12-25-2013, 11:15 PM Thread Starter
usramc's Avatar
Quoted: 2 Post(s)
New to psd's....
Ok fellas I've always been a cummins owner so I'm asking for a little advice/guidance here. Right now my trucks got new 17* hpop, 3" dp into 3.5" straight pipe, canned tunes on ts 6 pos, new fuel pump and new ad injectors. I did all this myself about 10k miles ago. Truck is a 5 speed. I would like to be near the 380-400hp mark. Gauges are already on the way. Im thinking of going with some stage 1's to 2's, 1.0 exhaust housing, ww2, custom tunes and maybe a diy efuel conversion purely because im tired of chasing leaks. Any imput would be greatly appreciated.
Early 99, 6 speed, ccsb, leveling kit on 35's, 6634, straight pipe, diablo chip.
usramc is offline
post #2 of 20 Old 12-25-2013, 11:48 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
Stage 1s will get ya 350rwhp but thats tapped out. To hit 400rwhp you need stage 2s. That 17* hpop will do alright but might run dry on WOT pulls. E fuel would be a good idea even on stock injectors.
I would avoid the 1.0 housing as its a restriction on anything past stock injectors with a stock turbo.
You will probably need a better clutch also
I am guessing you have a 97 cali model considering you are running split shot injectors?
Trucks and parts............
kanuck15 is offline
post #3 of 20 Old 12-25-2013, 11:56 PM Thread Starter
usramc's Avatar
Quoted: 2 Post(s)
No its a 96 non cali. I had 2 bad injectors and got these for almost free. The mpg on these suck but they do pull hard. I kind of wonder if they would pull harder if my chip was tuned for them.
usramc is offline
post #4 of 20 Old 12-26-2013, 12:00 AM
kanuck15's Avatar
Quoted: 10 Post(s)
so you have two AD injectors and the rest are AA injectors? The ADs are 140cc injectors but they need tuning to run properly. Actually I bet they are rather upset being in there.
Also side thought a stock turbo might not get you much past 350rwhp. You might be surprised
kanuck15 is offline
post #5 of 20 Old 12-26-2013, 07:11 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Your going to want to swap those ad's out for aa or ao code sticks if you don't have a Cali model, they are decent cores for when you want stage 1 or stage 2 sticks tho, your going to want to find out the health of your hpop by checking the DC% and psi, it may be new, but still stock and may not have the umph you need for the bigger sticks good luck
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 20 Old 12-26-2013, 11:11 AM Thread Starter
usramc's Avatar
Quoted: 2 Post(s)
Thanks guys, and no the whole set are ad's.lol. I should've been clearer on that one. So if i had tuning these ad's should net pretty good power being 140cc?
usramc is offline
post #7 of 20 Old 12-26-2013, 11:50 AM
kanuck15's Avatar
Quoted: 10 Post(s)
Yes they will give ya a pretty good kick over stock injectors
kanuck15 is offline
post #8 of 20 Old 12-26-2013, 12:15 PM Thread Starter
usramc's Avatar
Quoted: 2 Post(s)
Well i may just get the tuning done first and go from there then. Know of a tuner that will reburn the chip I've got to run them?
usramc is offline
post #9 of 20 Old 12-26-2013, 02:14 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Tony wildman, power hungry performance, swamps, etc etc, but Cary at ct performance or Raul at stealth performance can burn tw tunes for ya
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 20 Old 12-26-2013, 08:36 PM Thread Starter
usramc's Avatar
Quoted: 2 Post(s)
Thanks for being so helpful guys.
usramc is offline
