What next - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-23-2013, 02:36 PM Thread Starter
What next
I have a 95 powerstroke with 228k miles. The truck runs great and shifts very smooth. Recently picked up for a cheap price. I cut my cat and muffler and ran 3 inch straight pipe into a 5 inch mitre cut stack. I'm
Planning to do a chip and intake next. Bought gauges just need to install. My engine temp gauge is not working so I bought a replacement gauge. Also have boost and I'm thinking of getting a trans temp for the third gauge. What chip should I do? I was looking at the ts 6 pos chip. Any help would be great want to spend around $300 on a chip
Pbballer33 is offline
post #2 of 6 Old 12-23-2013, 02:40 PM Thread Starter
Also I purchased a 3 inch mbrp down pipe I need to install
post #3 of 6 Old 12-23-2013, 02:41 PM
Raul@Stealth Automotive's Avatar
if you only want to spend 300 on a chip then i would suggest a PHP chip...
as for the intake i would just do the DIY intake if you want an inexpensive fix to the stock air box... if your looking to actually replace it with an intake then i suggest AFE or S&B
-Raul
Raul@Stealth Automotive is offline
post #4 of 6 Old 12-23-2013, 06:45 PM Thread Starter
Is there a big difference between the php chip and the ts chip?
post #5 of 6 Old 12-24-2013, 08:02 AM
the diff is custom tunes.....
post #6 of 6 Old 12-24-2013, 04:42 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Agreed, also get an egt gauge along with a Trans gauge, I would have the sensor fixed on the factory coolant gauge iiwu
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
