Intake air cooling - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-22-2013, 05:48 PM Thread Starter
doyle95's Avatar
Intake air cooling
I'm making this thread to see what you guys prefer and think is better to use on these engines. What I am inquiring about is intercooling or water meth. Which do you guys prefer? I'm really looking into watermeth as I feel it is superior compared just intercooling. So does anybody have experience with either or insight on this. Also with the water meth how does it act in cold weather I would think that the meth mixture would prevent it from freezing but just a thought
Thanks guys
1995 FORD F-250
4in straight pipe
AFE Stage 2 Intake
FPR shim PHP Chip
Plans for truck
rosewood stage 2 budget built injectors
John woods race tranny
D66 Turbo
E-Fuel
6.0 Intercooler
6in lift in front on 4in lift in rear
20x12 fuel octane deep chrome
For sale
Stock Air Box off Obs with K&n air filter
Factory Spare tire more to come soon as i will be looking for a 6.0 here pretty quik if interested pm me
doyle95 is offline
post #2 of 4 Old 12-22-2013, 07:06 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I prefer intercooling, no fluid refill required, works all the time every time, water meth is nice and adds power and cools efficiently but requires refills when you run out
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 4 Old 12-23-2013, 05:38 AM
Sam Burton's Avatar
I've had both and while the water/meth worked great it did require a lot of refills and took up a good amount of space for the tank. it is surprising how much fluid you can use on any kind of pull.
the intercooler is more of a install and forget it kind of thing.
as for the freezing, yes the meth will prevent that as long as your mixture is right for the temp.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #4 of 4 Old 12-23-2013, 01:36 PM
dr.deere's Avatar
Quoted: 19 Post(s)
My thought is I'm gonna intercool my 97 main towing rig. And water meth my 94 sled pullin playing rig.
Sent from AutoGuide.com App
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
