Will a Perkins 2674A237 Turbo work on a 96 OBS 7.3 Powerstroke? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 12-11-2013, 04:41 PM Thread Starter
Hi guys and gals, I'm a proud new owner of a 96 F350 CCLB 4x4. Right now I have a Garrett Turbo (I was told it was a larger than stock but research seems to show its stock) Its an AlliedSignal 1825818C91. I also have another turbo laying around and I was curious to see if it would work and/or be an improvement over what I have. Its a Perkins P/No. 2674A237. 53271013081(6/7)a are the numbers on the casing. I've tried doing some research but all I have been able to come up with is turbos for sale that seem to be for earth movers or generators or something. It may be a stupid question but just putting it out there to see if anyone can shed some light on the situation. Thanks!
Kenton is offline
post #2 of 12 Old 12-11-2013, 06:02 PM
PSDTV21's Avatar
If you want to use it you will need to measure the base of the exhaust housing, find one that will fit or make your own, then up pipes, intake to the plenums, and lets not forget about oil. So my point probably more hassle and money than what is worth
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
post #3 of 12 Old 12-11-2013, 06:02 PM
theforeman57's Avatar
Quoted: 4 Post(s)
If it is off a perkins diesel, you might be able to find out the displacement, compare it to the 7.3, and go from there.
However, you might also be able to take it to a shop and have them measure it, examine it and give a rough cfm output on it. Bottom line is you still need to figure what mount it uses, route oil lines/ coolant lines, rework your entire intake and spyder,and then if you get all of that figured out ( many hours) you have to wonder if it will live under boost, and then try and find parts for it.
Not trying to rain on your parade, but its just not worth it Unless you can find a good source of info on the turbo. Again, not a stupid question, just imo not worth all of the hours. There are a lot of threads on the subject of mild power adders, the search button is your friend. Oh and
Axel --> 16yo
96 CCLB srw. built E4OD, Diy E-fuel, Autometer gauges
4:10 lsd, Toyo M55 on stock steelies
Future plans include diy Traction bars, and zf5 swap.
theforeman57 is offline
post #4 of 12 Old 12-11-2013, 06:03 PM
Quoted: 4 Post(s)
Dang it! second time today that I have been ninja'ed! lol
Axel --> 16yo
post #5 of 12 Old 12-11-2013, 06:06 PM
PSDTV21's Avatar
gotcha and
-Tyler
1994.5
PSDTV21 is offline
post #6 of 12 Old 12-11-2013, 06:30 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Ain't no call for no one legged ninji to be running around the trailer park
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 12 Old 12-12-2013, 05:14 AM
PSDTV21's Avatar
I think this train just went off the tracks..... lol
-Tyler
1994.5
PSDTV21 is offline
post #8 of 12 Old 12-12-2013, 06:13 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Have you seen my member status?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 12 Old 12-12-2013, 06:37 AM
PSDTV21's Avatar
Yes I have :
-Tyler
1994.5
PSDTV21 is offline
post #10 of 12 Old 12-12-2013, 01:52 PM Thread Starter
Thanks guys, yeah, like I said, I have it just sitting here rusting so I figured I'd ask but looks like I wont even bother with it lol
Kenton is offline
