when to use APR head bolts - Ford Powerstroke Diesel Forum
post #1 of 38 Old 12-03-2013, 05:35 PM Thread Starter
When would it be a good idea to use APR head bolts on a 7.3? Each cylinder is surrounded by 6 head bolts the 6.0 motor 4. I am reading that's why 6.0 had head gaskets problmes. How much modifying can be made to a 7.3 before considering APR head bolts?
scfdr13 is offline
post #2 of 38 Old 12-03-2013, 06:14 PM
theforeman57's Avatar
Quoted: 4 Post(s)
At some point, factory head bolts are just not going to cut it, no matter if you have 4 or 6. On a 7.3 you don't want to push past 40 psi occasionally, and no more than 35-37 daily.
So to answer your question, around 40 psi.
Also, if your pushing 40 psi ( which takes some doing) there is a host of other things to think about such as valve springs, pushrods, etc.
Axel --> 16yo
96 CCLB srw. built E4OD, Diy E-fuel, Autometer gauges
4:10 lsd, Toyo M55 on stock steelies
Future plans include diy Traction bars, and zf5 swap.
theforeman57 is offline
post #3 of 38 Old 12-04-2013, 04:11 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I thought somewhere around 70 psi you needed studs? Kause my Cali model tuned could get 37 easily and daily, just a time bomb or was it safe?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 38 Old 12-04-2013, 05:49 AM
Hate stupid people
CloverLeafFarm's Avatar
Quoted: 125 Post(s)
200cc injector or larger
Illiana Strokers DICtator
EFI Live tuned 6.7
CloverLeafFarm is online now
post #5 of 38 Old 12-04-2013, 09:31 AM Thread Starter
I am below both psi and injector size.... thanks
scfdr13 is offline
post #6 of 38 Old 12-04-2013, 10:24 AM
Hate stupid people
Quoted: 125 Post(s)
If you have injectors and you pass 40 psi, its extra insurance to put them in. Their on my winter to do list, my combo has me touching 47 going down the track. So its time
EFI Live tuned 6.7
post #7 of 38 Old 12-04-2013, 06:13 PM
choupique108's Avatar
anything past 35-40 it would be good insurance to go ahead and put them in.
1997 Single Cab Dually, S366 w/ Irate mount and plenums, EFuel, Intercooler, P.I.S 175/80s, Corbeau seats w 08 console, 19.5s, 6637, Black Interior with swede headliner and visors, Custom badges, Flight Fab Traction Bars.
choupique108 is offline
post #8 of 38 Old 12-05-2013, 06:55 AM Thread Starter
We"re talking turbo boost correct? Would there be another instance where ARP would be a good idea?
scfdr13 is offline
post #9 of 38 Old 12-05-2013, 07:18 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
The reason for studding the head is because of boost/compression, in some instances (especially with the 6.0) the boost will stretch the bolts and literally lift the head a bit and that's why people in high boosted applications go through head gaskets
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 38 Old 12-05-2013, 07:29 AM Thread Starter
Would adding a Snow methanol unit to the motor that's about 375 hp be one of those instances?
scfdr13 is offline
