Another adrenaline pump question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-01-2013, 07:25 AM Thread Starter
Whats the difference in the 2 pumps? Stock and adrenaline? I know more volume and pressure but how much more? I developed a oil leak front drivers side block area after installing the adrelaline pump a moth ago. Hard to find the leak but installing a long block Monday anyway. The new long block comes with upgraded oil rail plugs. Will the adrenaline pump cause more problems?
scfdr13 is offline
post #2 of 7 Old 12-01-2013, 07:33 AM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
Sounds like you didnt get the gasket quite right. The adrenaline should do you just fine
Trucks and parts............
kanuck15 is offline
post #3 of 7 Old 12-01-2013, 08:02 AM Thread Starter
I think it's the fuel rail plug. The motor has 300k miles. I wondering if new HPOP adrenalin one caused the leak. Oh ya it got down to 27 the night before. I usually use the block heater didn't this time. Cold block contracted seals. Or adrenaline too much for OEM seals and lines.
scfdr13 is offline
post #4 of 7 Old 12-01-2013, 09:12 AM
kanuck15's Avatar
Quoted: 10 Post(s)
Its probably just a miles thing, rubber seals wear out
kanuck15 is offline
post #5 of 7 Old 12-01-2013, 01:01 PM
If you think it's a fuel leak,then it has nothing to do with the Adrenaline. The HPOP flows oil only.
Rusty
rusty1161 is offline
post #6 of 7 Old 12-01-2013, 05:21 PM Thread Starter
cylinder head oil rail plug leak is what i meant to say. Not fuel rail my bad. Does the HPOP effect the effect the head oil rail?
scfdr13 is offline
post #7 of 7 Old 12-02-2013, 12:29 PM Thread Starter
Found problem. Leaking oil cooler line. New long block comes with new cooler. Adrenaline says pump should not cause problems on OEM long block set up.
scfdr13 is offline
