D66 hybrid/modified 6000 ft - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-18-2013, 10:52 AM Thread Starter
72Ford250's Avatar
So what is the thoughts on taking my D66 puting in the ww2 and putting a 1.0 housing on it? Would I see any benefits from this? Any bad negitive effects? Remember I am at about 6000 ft always. The truck has stage 2 (160/80) and puts the damn smoke out like you wouldn't believe before the turbo lights at full around 2100 to 2200 rpm. I usually only see about 24 psi at wot. And the truck is also a 5 speed.
I do support powerstroke power
1997 250 7.3L D66 Rosewood stage II t500 HPOP crx racing intercooled Mrbp 3'' down pipe 3.5 straight diy intake (chip is at the head doctor at bdp getting tunes)
1972 250 6.4L(390 FE.(gasser)
My Dads
2007 250 6.0L (325 hp stock
72Ford250 is offline
post #2 of 7 Old 11-18-2013, 03:08 PM
the baconator
terryknight's Avatar
Quoted: 148 Post(s)
you'll kick yourself for not doing it sooner. i have almost the same setup 160/100s with a D66 with a ww2 man it smoked,towing anything was a PITA changed to the 1.0housing more boost sooner, starts around 1300, less smoke, much less, EGTs are about the same the turbo runs out of air around 3100-3200 though
i'm at sea level
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 7 Old 11-18-2013, 03:22 PM Thread Starter
72Ford250's Avatar
Well that is good to hear 3 grand is where I usually stop with rpm and if I could get 1500 to 3000 rpm spool range I will be greatly happy
My Dads
post #4 of 7 Old 11-18-2013, 04:08 PM
choupique108's Avatar
should do much better with the 1.0 and the ww2. I had a stock d66 and was not very happy with it.
1997 Single Cab Dually, S366 w/ Irate mount and plenums, EFuel, Intercooler, P.I.S 175/80s, Corbeau seats w 08 console, 19.5s, 6637, Black Interior with swede headliner and visors, Custom badges, Flight Fab Traction Bars.
choupique108 is offline
post #5 of 7 Old 11-18-2013, 04:12 PM
c69ss396's Avatar
There are bunch of us that switched to the 1.0 housing, Nobody that has done it has had anything negative to say..
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #6 of 7 Old 11-19-2013, 08:22 AM Thread Starter
72Ford250's Avatar
Ok just bought a 1.0 housing off ebay brand new for 100 bucks. Now should I go with the ww2 or the bdp billet wheel?
My Dads
post #7 of 7 Old 11-19-2013, 08:47 AM
the baconator
Quoted: 148 Post(s)
can't help you there. i have a WW2. the BDP wheel comes intheir new D66 turbos. i think both will be fine
