17* HPOP Swap - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-18-2013, 05:18 AM Thread Starter
ja9788's Avatar
17* HPOP Swap
I was browsing the local boneyard this weekend and happened to come across an E350 SD ambulance So I figured I'd yank the HPOP off along with a few other goodies. Before anyone asks yes I have read the tech info on the swap as well as done searches and found some info but not exactly what I am looking for. There were a few guys on here explaining these will NOT work unless you have a 95.5-up. Is it possible to make this work on 94-95s? What would be the required steps to make this work?
< Joel >
95 F350 SCLB 4x4
- WW2
- 3" DP to 4" Straight pipe
- IDM 140v Mod
- TS 6 Pos.
- K&N Intake
- Glowshifts....
ja9788 is offline
post #2 of 10 Old 11-18-2013, 05:25 AM
PSDTV21's Avatar
Yes if you swap timing cover. I believe it will actually bolt up but it will probably leak.
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
post #3 of 10 Old 11-18-2013, 05:36 AM Thread Starter
ja9788's Avatar
The timing cover or HPOP? That seems to be way more of a PITA than it would be worth. What are the differences between the covers?
< Joel >
95 F350 SCLB 4x4
- WW2
- IDM 140v Mod
- TS 6 Pos.
- K&N Intake
- Glowshifts....
ja9788 is offline
post #4 of 10 Old 11-18-2013, 05:40 AM
PSDTV21's Avatar
The hpop. Yes it would be PITA because pulling the engine. There is very subtle differences. The 95.5 up have a different shape where the hpop mounts. I don't really know of any other changes
-Tyler
1994.5
PSDTV21 is offline
post #5 of 10 Old 11-18-2013, 05:43 AM Thread Starter
ja9788's Avatar
Thanks man
< Joel >
95 F350 SCLB 4x4
- WW2
- IDM 140v Mod
- TS 6 Pos.
- K&N Intake
- Glowshifts....
ja9788 is offline
post #6 of 10 Old 11-18-2013, 05:45 AM
PSDTV21's Avatar
No problem. As for getting an upgrade, I'd go for a t500 or something along those lines
-Tyler
1994.5
PSDTV21 is offline
post #7 of 10 Old 11-18-2013, 05:49 AM Thread Starter
ja9788's Avatar
That's been the plan to go with a terminator but I just happened to come across that 17* and I figured if I could make it work for the time being might as well right? Ah well. Just another core to add to the stack!
< Joel >
95 F350 SCLB 4x4
- WW2
- IDM 140v Mod
- TS 6 Pos.
- K&N Intake
- Glowshifts....
ja9788 is offline
post #8 of 10 Old 11-18-2013, 06:10 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Send it off or sell it, a t500 isn't to expensive any way, I'm stacking parts because I'm still unsure if my 95 is the later or older one since there are few differences anyway
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 10 Old 11-18-2013, 06:27 AM Thread Starter
ja9788's Avatar
Right but if I can get a couple hundred bucks off for sending in a couple cores I might as well!
Does Ford have a way to look that up by VIN? Or would you just have to literally tear it apart to find the differences?
< Joel >
95 F350 SCLB 4x4
- WW2
- IDM 140v Mod
- TS 6 Pos.
- K&N Intake
- Glowshifts....
ja9788 is offline
post #10 of 10 Old 11-18-2013, 07:03 AM
PSDTV21's Avatar
Matt knows the serial number for the engine. Let's wait for him to chime in :
OR you could look at the reservoir. The later ones have a different look to them.
-Tyler
1994.5
PSDTV21 is offline
