Injector pump finally gone belly up. - Ford Powerstroke Diesel Forum
post #1 of 17 Old 11-11-2013, 05:29 AM Thread Starter
After 320,000 miles I'm pretty sure my injector pump or high pressure pump is going belly up (they just don't make em like they use to). I haven't been on here in a while so I can't remember what type of pump to get if I'm going to upgrade my injectors. Any help would be appreciated. I will go with stage 2 injectors.
What? The cord hanging down? It's a hybrid.
97 250 - Dana swap, delete cat and muffler, Intake
hern is offline
post #2 of 17 Old 11-11-2013, 05:37 AM
atvrider93's Avatar
Quoted: 8 Post(s)
What's it doing that makes you think that's the problem?
sent from me
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #3 of 17 Old 11-11-2013, 06:12 AM Thread Starter
Its like its running out of fuel. It (injector pump) went out 2 weeks after I bought it new in 97.Its acting the same way, plus I've had pumps go out on Bobcats and New Hollands they have acted the same way. The engine light did come on and it will go from running normal to running as if its running out of fuel.
hern is offline
post #4 of 17 Old 11-11-2013, 06:32 AM
clatterindiesel's Avatar
Check under valve cover harness. Could be chaffed. Or burnt connectors. Open oil cap and sniff for a quick check of burnt electrical....most likely after its been running. Is it leaking any fuel?
I live close to ocala and surrounding areas, so if anyone ever needs a hand with their truck....get a hold of me.
clatterindiesel is offline
post #5 of 17 Old 11-11-2013, 06:32 AM
Or you can take valve covers off and full inspect.
post #6 of 17 Old 11-11-2013, 07:31 AM
Gaius's Avatar
Quoted: 43 Post(s)
Are you talking about the high pressure OIL pump, or the FUEL pump? Because these trucks don't have an injection pump like your tractor (or an early Cummins). What did you have to replace before?
You'll want to manually check your fuel pressure, and scan to see your Injection Control Pressure while running.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #7 of 17 Old 11-11-2013, 08:51 AM
Quoted: 53 Post(s)
^^^^^ This. Check ICP and IPR duty cycle via live data to know the status of the HPOP. Check fuel pressure via the schrader valve on the regulator.
madpogue is offline
post #8 of 17 Old 11-13-2013, 05:45 AM
Any word on what it was?
post #9 of 17 Old 11-14-2013, 06:57 AM
atvrider93's Avatar
Quoted: 8 Post(s)
Check your oil level.
Is it intermittent?
sent from me
6637
OBA w/horn
DE 5"
PHP tunes
2008 Wr250X
post #10 of 17 Old 11-14-2013, 07:00 AM
Gaius's Avatar
Quoted: 43 Post(s)
He can't answer. He's still trying to find his injection pump.
05 F350 Crewcab
Gaius is offline
