Big power question
Alright guys here is the deal. I have a '96 psd 2wd auto, gauges intake 4" exhaust, 60hp chip and 316,000 mi. I want to go at least 400-450hp with the option of going up to 500 if I get a wild hair. Of course money is an issue but it takes second place to doing this the right way and making the truck last. I am prepared to pull the motor and do whatever I have to do to get it right. Let me know what you think on everything I should do including engine work. Oh yea and I want it to be my daily driver. Thanks guys
buy a 6.4 and ur over half way there
yea but then I would have to look at every day...
i would say start off with injectors, high pressure oil pump, turbo, chip, intake and turbo-back exhaust and then wait till something breaks.... I'm planning on buying a 6.0 to mod up rather than blow up my OBS
Don't wait until something breaks. It will cost that much more to replace the trashed parts like the block and cam, oil pan, oil pickup etc from a flailing rod.
If you plan to make 400-450 I'd get a set of hybrids, head studs, and something like an H2E turbo or one of the turbos that WOP has available that fits on the Hypermax H2E install kit. You might need a 17° hpop as well depending on how yours is. If you want the option to go more than that I'd pull the engine and do a rebuild. I'd have the decks trued, new pistons, bore job, have the crank checked and turned if need be, Crower rods, ARP main studs, new valves, new valve guides, new valve springs set up to properly take the amount of boost you think you'll be running, head studs, and fire ring head gaskets. That should pretty much get the engine where it needs to be. to not have to wory about anything letting go in the bottom end. Then I'd go with a set of BD code injectors and an oil system. For the turbo I'd contact either David Lott at Diesel Innovations about his GT42 kit or WOP and tell them what you are looking to do and they can set you up with a turbo kit. You are going to need a built transmission what ever you do. I'd give Brian at BTS a call for that. |
Here's my list of mods and I'm at 450+ at the wheels on fuel only.
Hybrids Injectors, 910 Valve springs, Chromoly pushrods, H11 Head studs, Forged Rods, Garrett 38R turbo, DIY fuel system, 17* hpop, and a BTS transmission. Of course I have Intake/exhaust/gauges and a few other one offs, but that's about it. I recently ran a 13.0 @ 102 with a small shot of spray with a bad exhaust leak. |
thanks guys for all the input. its going to be about a year and a half project so thats why i want to do it right. and im def. going to pull the motor and go through it at least so i can have peace at mind when i stand on it every time. thanks gts and maintain you def got the wheels turning in my head!
