what to do for good power levels? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 08-01-2008, 01:01 PM Thread Starter
ZF-BB's Avatar
Me and my buddy are building his 1996 7.3 reg cab long bed into a sled puller, it has a manual tranny in it. I am not too familiar with blue ovals but I told him I would try and get some info on power upgrades. Our first thoughts were injectors, performance chip, upgraded fuel pressure? looking for around 500hp, we havent found that money tree yet! Any advice would be very much appreciated.
2002 silverado 8.1l ZF-6-speed
6 inch pro comp
ZF-BB is offline
post #2 of 20 Old 08-02-2008, 08:08 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
500 HP:$$$$$$$$$$$$$$10-15k
Big inj
Stealth
Dual SD fuel system
Bean's modded H2e
Studs
3" intakes
Girdle
Tony Wildman tunes
Cary
CT Performance, Inc. is offline
post #3 of 20 Old 08-03-2008, 05:21 AM
lukecline
Guest
Posts: n/a
Quoted: Post(s)
you could probably trim the cost down a bit. You shouldnt add a girdle w/o having the main bore aligned. when you torque the studs it distorts the main bore. Also it can be done with hybrid injectors so that means saving 2k on dual hpop.
post #4 of 20 Old 08-03-2008, 05:31 AM
PSDfan99's Avatar
500hp
Stage 3 Hybrid Injectors
H2E turbo, or a TN BB or Garrett BB might do.
Custom tuning, DP-Tuner/ Tony wildman
Regulated Return fuel system
Intake/Exhaust
Head Studs
Valve Springs
Push Rods
Then some transmission upgrades....
It aint cheap, but you gotta pay to play.
Early 99 F-350
4" lift on 33's
Tymar Intake, Isspro Gauges, Modded IDM, HPX, Boost Fooler, 4" Exhaust
-BTS Tranny
-76mm Sledgehammer
-Swamps Tuning
-230cc Casserly Hybrids
-T.E. Modded 17* HPOP
-ARP's, Chromoly's, 910's
-ITP RR
-Jake
PSDfan99 is offline
post #5 of 20 Old 08-04-2008, 05:06 AM Thread Starter
ZF-BB's Avatar
We were hoping to stay under 10k for sure, so I guess 500 hp very isnt realistic then. i just kinda threw that number out there hoping it would be possible.
6 inch pro comp
ZF-BB is offline
post #6 of 20 Old 08-04-2008, 09:27 AM
Being you are starting off with a '96 you will need a fuel system that will run about $1000 and may need a 17° high pressure oil pump wich you should be able to source on Ebay for a decent price. Probably $200ish I'm guessing. Maybe less. Hybrid injectors going to run in the $2000 neighborhood. Turbo kit going to run in the $2500 range. I would go either with the Hypermax H2E or one of the turbos that WOP uses on that same mounting kit. Chip, gauges, exhaust, intake going to run you around $1000 depending on how much you do DIY style or what kits you buy. You're going to need a good clutch. Not sure what they are running these days as I have an auto but I don't think they are cheap. Maybe $500+? There'll be some other odds and ends in there as well. That stuff should be the basic stuff to get you to the 450hp range anyway. Maybe 500.
'96 F-250 Extended Cab, long box 4X4, 4" lift, 35" tires
Injectors, Intercooler install kit-GTS Motorsports
Crower rods, H11 Head studs, Cam, Chip Diesel Innovations
Gen II HPOP, chip-Swamp's Diesel
Chip Live Tuned from Power Hungry
Current Chip Tuned by me!
Transmission BTS
custom turbo kit with HX40.
12.683@105.65 in 1/4 mi!
466hp #2 only
805hp N²O
Yeah I can keep up!
gtspowerstroke is offline
post #7 of 20 Old 08-05-2008, 06:02 AM
Koonswala's Avatar
id do what you got the cash for. every one has my idea and it will still outpull a chev. any day lol
Koonswala is offline
post #8 of 20 Old 08-05-2008, 06:55 AM Thread Starter
ZF-BB's Avatar
hey, easy there, theres finally getting to be some dmax's that can pull. I do like the 7.3 though, I just wish ford wouldve stayed with it longer instead of going with these smaller diesels. I know a lot of guys that have either bought a cummins or a dmax because they dont like the newer powerstrokes, and those guys have always been die hard blue oval lovers!!
6 inch pro comp
ZF-BB is offline
post #9 of 20 Old 08-05-2008, 07:00 AM
blowinsmoke4life's Avatar
Quoted: 2 Post(s)
Garage
Send a message via AIM to blowinsmoke4life
i guesss everyone forgot u gonna need to upgrade the rods anf prolly get a fluiddamper jus to keep down vibrations in the crank
1999 F250 CC SB 4x4 4r100 ts chip w/ php tunes
1989 F350 CC LB 4X4 N/A 7.3l IDI zf5 swapped and rebuilt engine. sold
blowinsmoke4life is offline
post #10 of 20 Old 08-06-2008, 05:04 AM
benderado's Avatar
being hes got the ol' handshaker, the clutch difinetly needs upgraded. You might beable to get away with a dual disk but I know for sure a tripple disk would stand up to sled pulling. South Bend makes a great triple disk but the price is a bit steep at around $1100
HI.....I'm Kyle
RIP: 1996 F-250 X-Cab Long Bed
Now: 2006 Ram 2500 CC SB SLT 6 Speed
benderado is offline
