Stainless DP with Exhaust Wrap? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-01-2013, 03:09 PM Thread Starter
So here's the thing... starting to build the White/Silver F250 and it's a low miler the intent is to keep it for some time. Currently has 62,000 kms yup 40,000 miles. Have never been an advocate of a SS exhaust... however given I'm keeping it and looking at the aluminized DP on my current truck (in ok shape but starting to rust) and parts truck (it's done, rusted through at the bell end). Was wondering if anyone has installed a stainless down pipe wrapped in exhaust wrap? Thinking is the wrap will keep the elements off it and perhaps be a bit cooler on the cab floor and the stainless with prevent the rusting that is what I have read via heat cycling when under wrap.
I don't have ceramic coating close at hand (that I am aware of) nor do I know how long it lasts.
Thoughts?
jrc
'97 Red F250 CC XLT ZF5 3:55s, Dana 60, SD springs all round, 'jectors, IC, 6.0 fan, TW files, VisionX lights and other stuff.
'96 White/Silver F250 SCSB 4X2 (all stock for now)... 4:10's E4OD.
jcart is offline
post #2 of 6 Old 11-01-2013, 03:38 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 76 Post(s)
Feedback Score: 7 reviews
the negative i see, is if the elements get under the wrap they will probable get trapped there and cause more damage.
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
powerstrokeshellback is offline
post #3 of 6 Old 11-01-2013, 09:59 PM
rednex3's Avatar
Pipe wrap looks cool, but there's a reason I don't run it on my Harley anymore. I found that it actually contributed to the pipes rotting quicker. Had the rear pipe crack and break off about 1 1/2" from the exhaust manifold and when I took the wrap off the pipes, they were severely pitted. This took place in under a year and the pipes were new when the wrap was installed. Other's experiences might be diffterent.
95 Ext Cab F250
Dana 60 Swap
MBRP Turbo Back Exhaust
AFE Stage 2 Intake
Stock Injectors
1.0 Turbo Housing with Wicked Wheel 2
Bar None E-fuel kit
Bar None Bellowed Up Pipes
Isspro Guages
2 Rigid Industries 30 SRLs (worth every penny!)
All sittin on 35" Toyo Muds
So much more planned as $ allow!!
rednex3 is offline
post #4 of 6 Old 11-02-2013, 05:20 AM Thread Starter
Good to know thanks for the insight.
jrc
jcart is offline
post #5 of 6 Old 11-02-2013, 07:21 AM
m j
I wouldnt wrap
ceramic coating is inexpensive (if you use the satin black 2000deg) and there are at least two places here in the fraser valley
I used Rocket in Abbotsford for my turbine housing and it was $65
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
post #6 of 6 Old 11-02-2013, 07:32 AM Thread Starter
Originally Posted by m j View Post
I wouldnt wrap
Thank you Sir! I'll check into that for sure.
jrc
jcart is offline
