Hpop questions ?? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-01-2013, 08:35 AM Thread Starter
Hpop questions ??
I have a 1995 7.3 and I was really leaning toward an adrenalin hpop but when I went to purchase one they said they didn't carry it for my year can any one give me some more suggestions on an hpop ?
Sparchuleta is offline
post #2 of 12 Old 11-01-2013, 10:55 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
SRP and Terminator Engineering make HPOPs for your truck but T. Engineering (I think) requires you to send yours first. 94.5 and 95's have a different front geardrive cover and they use a different HPOP. If you ever have the motor out and access to the front end swap it with a 96-03 front cover.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 12 Old 11-01-2013, 11:09 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
I thought that 95.5s actually had the newer front cover is that true? Im pretty sure mine is a 95.5 but i have no other obs truck to compare the front covers. That would be something to look at. The 1995 is a mutt era of lots of oil system changes
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #4 of 12 Old 11-01-2013, 11:49 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
True, since his order was already declined I just went the simple straight '95 answer.
Matt
'97
-Stage II trans.
BigFuel is offline
post #5 of 12 Old 11-01-2013, 11:59 AM
Chapter Director
Quoted: 5 Post(s)
Maybe they didnt ask him that so thats why i threw it out there. But do you know what the cutoff dates are for the E95 and L95?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #6 of 12 Old 11-01-2013, 12:09 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Yep, not a date. Engine SN# 216543 was the last of the old timing covers. If your engine is lower than this then you have a old timing cover.
Matt
'97
-Stage II trans.
BigFuel is offline
post #7 of 12 Old 11-01-2013, 12:13 PM
Chapter Director
Quoted: 5 Post(s)
OP you could check that out maybe you have the newer cover. But Jesus matt do you have all this random info like rattling around you head or do you have the holy bible of all tech books
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #8 of 12 Old 11-01-2013, 12:24 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
OP, look around the oil filter on the block that is where the serial number is. You only need to see the last 6 numbers.
Pat, I have a form of Aspergers Syndrome. Sort of an extremely high functioning human with tons of anti-social behaviors. We live in our own world. My thing is numbers/math/puzzles/and relations (like how things compare to others). This is why I am seen as kind of an a**hole around here. Kris used to live down the freeway a bit from me but I never met up with him, couldn't handle meeting someone new. Can't even talk to him on the phone. Text, email, formum all day long but don't use my phone for talking. I hate groups, and when I find something I like I never change from that again. I actually get mad when my wife changes slightly a recipe that I like. I'm not the easiest person to get along with...
Matt
'97
-Stage II trans.
BigFuel is offline
post #9 of 12 Old 11-01-2013, 03:15 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
dieselsite used to offer an adrenalin pump for the early truck
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #10 of 12 Old 11-02-2013, 10:15 PM
Jennifer@Dieselsite's Avatar
Quoted: 4 Post(s)
We've always offered it.
OP, I don't know who you spoke with here at DIESELSITE, but we most certainly carry a pump for you and I am so sorry you got incorrect information.
http://www.dieselsite.com/1994-20037...alinehpop.aspx
Simply choose the 94-95 option from the drop-down box when you add it to cart.
This model is a little different as it requires the anti-drainback and it will come with the correct mounting gasket and o-rings. It also has the perk of being able to use the 96-03 style IPR (I believe the 94-95 gets really pricey).
Jennifer@Dieselsite is offline
