3:73 gear in 96/97 Diffs? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 11-01-2013, 07:15 AM Thread Starter
Hey Guys not sure if I have this posted in the correct forum...Mods please change if need be.
Have a 96 F250 SCSB 2x4 E4OD that I'm intending on swapping to 4x4 and am chewing on different differential ratios. Currently has 4:10 rear (and D60 to go in is 4:10 too). Will 3:73 from SD axles fit?
Thanks,
jrc
'97 Red F250 CC XLT ZF5 3:55s, Dana 60, SD springs all round, 'jectors, IC, 6.0 fan, TW files, VisionX lights and other stuff.
'96 White/Silver F250 SCSB 4X2 (all stock for now)... 4:10's E4OD.
jcart is offline
post #2 of 17 Old 11-01-2013, 07:51 AM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 80 Post(s)
Feedback Score: 7 reviews
keep the 4.10s...
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
powerstrokeshellback is offline
post #3 of 17 Old 11-01-2013, 08:05 AM
I have 4:10 in my 95 and they have great low end torque for pulling but once I get out on the highway I rap out at 70 and like 2500 -2700 rpm and to me it's way higher then my liking so I was thinking about 3:73 to drop my Rpms but still keep my torque so it depends on what you plan on doing with the truck
Sparchuleta is offline
post #4 of 17 Old 11-01-2013, 09:51 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
2500-2700 RPM
Do you still have factory size tires? I have 4.10's 32" tires and I'm doing below 2400RPM at 70 and getting 18.2 MPGs unloaded and 14.5-15.2MPGs hauling horses. Maybe you need to calibrate your speedo?
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #5 of 17 Old 11-01-2013, 10:42 AM Thread Starter
This F250 SCSB 4X2 will be swapped to 4X4 and D60 (as I have one on hand, with most all the other swap stuff). The intended use is for a DD work commuter (that can do anything) that will tow the periodically. So there is a bias to good mileage and I intend on keeping the E4OD (I think for now). 4:10s are too low for my needs and I don't intend on running bigger then 35" tires it's not a dedicated tow rig, my red sig truck has 3:55s with 35" with the ZF-5 and works very well. Thinking would like to try 3:73 as it might be a good compromise between the two ratios.
jrc
jcart is offline
post #6 of 17 Old 11-01-2013, 02:44 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
you can use SD axles rear is bolt in the front will require an RSK which is a problem in a 2WD truck (so i've heard).
personally i also hate 3.55s and 3.73s then again most all i do is tow. i also get better fuel economy with 4.10s then 3.73s or 3.55s
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #7 of 17 Old 11-01-2013, 03:55 PM Thread Starter
thanks Terry, the notion is to use the housings I have and do a gear swap and I was wondering if SD gears (in 3:73) from the respective front/rear possibly used might be more readily available then new.
In terms of problematic RSK on a 4X2 frame how so? I'm thinking I might have to box in the frame ends from a F350 to the recipient truck although I have just looked and not measured much save for the overall width seems the same (across front, meaning fender frame mounts measure the same width wise) from truck to truck.
jrc
jcart is offline
post #8 of 17 Old 11-01-2013, 04:14 PM
the baconator
Quoted: 146 Post(s)
the SD front axle up to early 02 was a D50 so that won't work in a D60. the rear axle is a Sterling 10.5 yours is a sterling 10.25 so they won't work either. after market gear sets run about 200 ish but install at a shop will run more like 700+
post #9 of 17 Old 11-01-2013, 04:26 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Actually if you get a dually front axle, they were d60
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #10 of 17 Old 11-01-2013, 04:33 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
All 350s had 60s, 03-04 they were all 60s
Trucks and parts............
kanuck15 is offline
