PLEASE HELP!!!!!!!! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-31-2013, 08:00 AM Thread Starter
dirtbiker109d's Avatar
PLEASE HELP!!!!!!!!
I have a question that i cant find the answer to so i came to the org. Iv scene in Tom S's truck right below the ash trey a black moduel thing. It has a little screen and some buttons around it. and im pretty sure it has A ford oval on it o it looks OEM. What is this and what does it do? is it like a transcommand? please help!
dirtbiker109d is offline
post #2 of 8 Old 10-31-2013, 08:04 AM
Raul@Stealth Automotive's Avatar
i would have to see the picture but i believe you are talking about a high idle module that ford used to put in the OBS trucks
Raul@Stealth Automotive is offline
post #3 of 8 Old 10-31-2013, 08:21 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Aux Idle Control
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 8 Old 10-31-2013, 08:26 AM Thread Starter
yes thats it! what does it do exactly?
post #5 of 8 Old 10-31-2013, 08:34 AM
Heavy_GD's Avatar
Quoted: 1496 Post(s)
Feedback Score: 3 reviews
I have em on a tow truck, bumps up the idle and engages the PTO
You can set the RPM ranges and bump it up and down as needed using one winch vs two vs jump starting vs idle. etc.
Im sure there are other applications like rigs with pumps, cranes, lift gates, compressors ect.
GD
Heavy_GD is offline
post #6 of 8 Old 10-31-2013, 08:40 AM
Heavy_GD's Avatar
here is the manual if you want it
https://www.fleet.ford.com/truckbbas...pcm_manual.pdf
GD
Heavy_GD is offline
post #7 of 8 Old 11-03-2013, 01:12 AM
Thanks Heavy_GD always wonder how that worked now I know! Loaded it on the phone and will give a whirl when it gets light out.
Thanks again,
jrc
'97 Red F250 CC XLT ZF5 3:55s, Dana 60, SD springs all round, 'jectors, IC, 6.0 fan, TW files, VisionX lights and other stuff.
'96 White/Silver F250 SCSB 4X2 (all stock for now)... 4:10's E4OD.
jcart is offline
post #8 of 8 Old 11-03-2013, 05:27 AM
Heavy_GD's Avatar
No problem, it took me a while to figure it out which is why I had that link saved
GD
Heavy_GD is offline
