Installing IC on an OBS - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-24-2008, 04:49 PM Thread Starter
Shaking the Bush Boss
CHUCK's Avatar
Question Installing IC on an OBS
Any help is welcome....
I am installing an I/C from a 02 7.3 into my 96 f250. I ordered the techni cooler pipe kit from banks. Does anyone know if there is a lenth diffrence (shorter) where the pipes connect to the I/C, between the banks I/C and the stock 02 I/C.
Seems the only way to get the i/c close to the rad. support is to cut about an inch off of the i/c pipes that came in the kit. Anyone know?
Chuck
CHUCK is offline
post #2 of 13 Old 07-24-2008, 10:03 PM
I haven't used the Banks pipes to install one yet but I think the fittings on the Banks coolers come out farther than the SD coolers do. So if anything I'd imagine you'd need to get some longer boots like the stock Ford boots for it. When I had my site up I had a nice write up on installing them but it's not back up yet. I've installed quite a few with the kits I used to have so if you have any questions feel free to give me a hollar.
'96 F-250 Extended Cab, long box 4X4, 4" lift, 35" tires
Injectors, Intercooler install kit-GTS Motorsports
Crower rods, H11 Head studs, Cam, Chip Diesel Innovations
Gen II HPOP, chip-Swamp's Diesel
Chip Live Tuned from Power Hungry
Current Chip Tuned by me!
Transmission BTS
custom turbo kit with HX40.
12.683@105.65 in 1/4 mi!
466hp #2 only
805hp N≤O
Yeah I can keep up!
gtspowerstroke is offline
post #3 of 13 Old 07-25-2008, 07:19 PM
How much did the pipe kit cost directly from banks?
1995 F250 7.3 turbo
3 inch dp into 4 inch exhaust
tymar intake, Isspro boost, pyro, tranny temp gauges
tow and go shift kit, DIY electric fuel pump system with fuel pressure gauge,bronco tank mod
kcm ss hpx line, stancor gpr, 203 thermostat, 03 starter
TWchip 6 postion daily,econo,tow,street,xtreme,highidle
Banks intercooler and pipe kit,Idm Mod,CCV Mod
Plant drive wvo kit(hotfox,vegmax filters,26fphe, vegthermmega and gauges for cooliant and wvo temp)
Dana 60 front axle swap
7.3TurboDiesel is offline
post #4 of 13 Old 07-25-2008, 07:20 PM
h2odrx's Avatar
so what is the best fit?
Remember, we aren't eating this stuff, we're turning it into diesel fuel. Your truck only cares about viscosity, acidity, and BTUs. Nothing else. -unknown?
NC State law defines biodiesel as ''any fuel or mixture of fuels derived in whole or in part from agricultural products or animal fats or wastes from these products or fats.''
h2odrx is offline
post #5 of 13 Old 08-06-2008, 07:29 AM
wbones9 is offline
post #6 of 13 Old 08-06-2008, 08:17 AM
h2odrx's Avatar
now where did she hide my wallet?
h2odrx is offline
post #7 of 13 Old 08-06-2008, 09:05 AM
Originally Posted by wbones9 View Post
nice write up.
Kyle
1lowdiesel is offline
post #8 of 13 Old 08-06-2008, 09:10 AM
I have the dimensions (lengths and angles) of the pipes on my camera san disk card... unfortunatly I can't get them off the card since my camera is being repaired at canon.
Off the top of my head, I used
1 45deg tight radius tube
1 45 deg long radius tube
1 55 deg tight radius
2 90 deg long radius tubes
wbones9 is offline
post #9 of 13 Old 08-06-2008, 07:41 PM
Is their much advantage to upgrading to a 6.0L intercooler or would a 7.3 work just fine. I have the banks kit on the way.
1995 F250 7.3 turbo
post #10 of 13 Old 08-06-2008, 07:47 PM
Curious, what did you pay for the banks kit? what all was included?
wbones9 is offline
