replacement fuel tanks? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 07-20-2008, 07:25 PM Thread Starter
of course the tanks on my 97 are leaking a little and its time to replace them. should i just buy factory replacement, or is there a nice aftermarket set of tanks i should be looking at?
scubanaoh24 is offline
post #2 of 17 Old 07-20-2008, 08:15 PM
there is a place in corona ca. called areo tanks that makes over sized replacment tanks
1996 CC duelly
3.5" down pipe
4" exhaust NO MUFFLER
K&N fipk
superchip
fpr "bb" mod
2005&2006 VRA Dwarfcar champion
dwarfcar63v is offline
post #3 of 17 Old 07-21-2008, 10:40 AM
ricksstang's Avatar
Transfer flow also makes oversized fuel tanks. But they aint cheap. I believe they run about $800.00.
Rick
Aftermarket and OEM Fuel Tank Systems
AeroTanks-we specialize in auxiliary fuel tanks.
ricksstang is offline
post #4 of 17 Old 07-22-2008, 03:08 AM
CSXPAID's Avatar
I just put two new spectre tanks from rock auto in my truck they are a stock replacement tank and the are great quality
Truck Pics and How-to
CSXPAID is offline
post #5 of 17 Old 07-22-2008, 04:26 AM
You can ditch your rear 20 gallon tank in favor of a 33 gallon Bronco tank, but your spare tire has to go.
You can also go with stock size Poly tanks from MTS Company. I had one of theirs many years ago. Price was good, it didn't fit real well but it worked. I've heard from others that their newer tanks fit better. Biggest issue I had with the poly tank was the oem Ford vent wasn't large enough and the tank would expand 2" to 3" in the heat.
I've been toying with welding 2 steel tanks together to get a larger front tank. Lots of room under there on my cc sb...
An OBS or 2, or 3...
DZL JIM is offline
post #6 of 17 Old 07-22-2008, 04:36 AM
mrnecsteve's Avatar
Stainless steel I hope!
mrnecsteve is offline
post #7 of 17 Old 07-22-2008, 09:14 AM
Transmission or Injectors
lwillson's Avatar
I have also been dreaming of doing this as well. I think I did the math, and it would add another 11 gallons of fuel for the front tank, with the tank going from the rear differential to the transfercase at the front.
Does it really need to be stainless?
lwillson is offline
post #8 of 17 Old 07-22-2008, 11:48 AM
Ummm, no...
No need for $$$ stainless steel, it's just a fuel tank...
DZL JIM is offline
post #9 of 17 Old 07-22-2008, 01:35 PM
mrnecsteve's Avatar
Ummm, no...
First choice : stainless
second choice: aluminum
third chice: plastic with steel cage or guards
fourth choice: factory galvanised/electroplated steel
last choice: bare steel (for disposable vehicles only)
post #10 of 17 Old 07-22-2008, 05:28 PM
FYI, your 'Bare steel' is cheapest and easiest to work with and when treated with the proper industrial primer and paint will last at least the life of the truck.
Been there, done that...
DZL JIM is offline
