Cat delete and state inspection - Ford Powerstroke Diesel Forum
Old 07-20-2008, 03:00 PM
I got a question that involves the state inspection in Texas. If I get a cat delete pipe for my 97 F350 will I still pass state inspection or do I need to bolt the kitty back in every time? The reason why I ask is because I once didn't get the sticker because my exhaust on my Yota Truck was rusted pretty bad. Anyone in Texas run into any problems without the cat yet?
Thanks
Old 07-20-2008, 03:06 PM
Raging Lunatic
At this time you should not have any problems. Saftey inspection only no emmision testing. However with that said some Counties inspect for modifications to the emmision system and turn you down. I have not had any issues and have mine inspected in the Metroplex and the testing is usually more stringent here. Good luck.
Old 07-21-2008, 05:40 AM
Safety Inspection ALSO includes Visual Check of Emissions equipment, this is a REQUIREMENT for EVERY county in Texas.....
BUT,
None I have used in the past EVER does it
Normally, if you are FAILED at one location, drive down the road and go to another location
Old 08-02-2008, 08:38 PM
Location: West Jordan UT, Currently working in Colo. Springs CO.
same deal here in Utah, I kept mine just incase the laws change, the place I go told me all they do is look under the truck to see if I have a muffler, no cat req, but you never know, might aswell keep it so you don't need to buy another one if you need it.
Old 08-05-2008, 05:55 AM
i have never had anyone look under my rig i am in texas all the time once you get the sticker you are good to go
Old 08-05-2008, 06:53 AM
I just caught a little flack for it not being there, but I still got the sticker.
