6.0 intercooler questions - Ford Powerstroke Diesel Forum
post #1 of 10 Old 10-22-2013, 02:22 PM Thread Starter
Psd171's Avatar
Okay so I was on Craigslist and came across a 6.0 intercooler. And called the guy for giggles. He said he didn't know what it was worth and wanted 50 bucks for it. So for one is it doable to put one in our obs trucks? And can you get a kit for the pipes ?
Psd171 is offline
post #2 of 10 Old 10-22-2013, 02:59 PM
the baconator
terryknight's Avatar
Quoted: 153 Post(s)
yes it's worth it yes you can put it in our trucks and yes thee are pipe kits out there
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 10 Old 10-22-2013, 03:06 PM Thread Starter
Psd171's Avatar
How much fab work is required? Does the radiator need to move ? And what about the spyder can you get those? I'm just kicking it around and trying to find out about it because the intercooler itself is so cheap.
Psd171 is offline
post #4 of 10 Old 10-22-2013, 05:42 PM
CSIPSD's Avatar
You will need an E99 intake spider and a couple sets of pipes...
I've done it before, not hard, just not drop in.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #5 of 10 Old 10-23-2013, 05:00 AM Thread Starter
Psd171's Avatar
Okay did you guys re route your CCv?
Psd171 is offline
post #6 of 10 Old 10-23-2013, 09:21 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
CCV is before the turbo not after where the IC install will be [EDIT: don't know why I needed to type that. I was working on my cousins SD yesterday and must still be in SD mode]. And yes, most of us flip the house and run a 1/2" hose down and under the truck to be dumped. No smog in Cali means I run open and free. Take that mother Earth! She's only crying because she's losing.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #7 of 10 Old 10-23-2013, 09:58 AM
the baconator
Quoted: 153 Post(s)
yes if you don't you wind up with oil in your IC
post #8 of 10 Old 10-24-2013, 06:57 AM Thread Starter
Psd171's Avatar
Are there any other options other than an e99 spyer? That I do not have to buy a whole kit for? Or can I get an e99 from the dealer now? Maybe someone knows the part number ? Thanks for all of your imput guys really appreciate it.
Psd171 is offline
post #9 of 10 Old 10-24-2013, 07:36 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
E99 spyders are discontinued when the 3" SD spyder arrived. I _think_ tylmar sells just their spyder. I believe you can get it from Cary@CT_Performance on here or from Complete Performance out of Texas. There is nothing to complicated about it except how thin the wall is on the pipe. A competent exhaust shop should be able to make you one from a good picture.
BANKs sells individual pipes but he is wicked expensive.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #10 of 10 Old 10-24-2013, 03:44 PM Thread Starter
Psd171's Avatar
Okay another question what size are the intake and outlet port sizes on the 6.0 cooler ? Because they are 2in on the e99 correct?
Psd171 is offline
