another T4 turbo question - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-17-2013, 07:43 PM Thread Starter
shoopie's Avatar
so im doing a t4 conversion on my obs and i have a question. are all t4 turbos the same? meaning is a s366 meant for a cummins the same as one sold for a powerstroke? or even a honda for that matter? are the compressor housings all mounted the same way on them? as in facing the same direction...
id just rather not spend the $1200 from swamps or somewhere when i can get the same turbo somewhere else for almost half the price
many thanks ahead of time
1996 RCLB 7.3L auto
ARP Head studs, 3" DP, 5" stack, Riff Raff 6637, Isspro ev2 gauges,
Motor is on the stand getting rebuilt with some extra goodies...stay tuned
East Hampton, NY
shoopie is offline
post #2 of 5 Old 10-18-2013, 08:27 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
I don't know that much about the T4 setups but I do know this. Most of these turbos that I have worked with use a band clamp to hold the housing to the center section. This allows you to rotate to fine adjustment which direction the ports are facing. That said I do not believe the turbo from a smaller engine will feed our 7.3L's the same as it feeds the engine the turbo was originally setup for. A 5.9 takes and expels less volumetric "air" than a 7.3L per rotation. This turbo would spool quick but would run out of steam just as quick on our trucks. Getting the right parts to make it work is doable hoping from junkyard to junkyard but will most likely cost a bunch of time and math.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 5 Old 10-18-2013, 09:30 AM
Ford7three's Avatar
If you are spending 1200 on a s366 you are paying waaaay to much. there are tons of options on a 366, the one we offer is 850 shipped for a reference.
Ford7three is offline
post #4 of 5 Old 10-19-2013, 05:12 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
There are many variations of the s366. The 366 is just the frame. U have to look at the inducer and exducer specs, ratio of the housing, overall cfm flow ect....
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #5 of 5 Old 10-19-2013, 08:43 AM
m j
s300 is the frame 66 is the compressor inducer
I would go s400, s467fmw is what I bought
the only way to compare is with the part number. there are housing options on both sides, the dodge guys seem to use the right angle compressor outlet and a t3 turbine housing.
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
