dp tuner or ts6 and guages - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-17-2013, 04:32 PM Thread Starter
mksnipe's Avatar
So I'm getting ready to buy a programmer and want to know what I should go with? I'm leaning towards the dp tuner infinity. What I want to know is will I get decent readings with the infinity or should I go with a ts6 and run my own sending units? I like the fact the infinity can view and clear codes but am worried the stock sending units aren't suitable for accurate readings. I'm hoping some guys that have had both can chime in. Thanks for all info.
1995 F350 CCLB
purchased 05/01/2013
160/30 powerstruck injectors
TS6 chip
Custom intake
MBRP 3" DP & 4" exhaust
E - fuel
Transgo HD2 shift kit
FUTURE
upgrade HPOP
D66
Intercooler
done?...for now
mksnipe is offline
post #2 of 12 Old 10-17-2013, 05:31 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
talk to kris (351fifty) he has the infinity and had gauge before. he has 6pos with both set ups (i believe)
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 12 Old 10-17-2013, 05:53 PM Thread Starter
mksnipe's Avatar
Thanks I will
1995 F350 CCLB
TS6 chip
Custom intake
E - fuel
FUTURE
upgrade HPOP
D66
Intercooler
done?...for now
mksnipe is offline
post #4 of 12 Old 10-17-2013, 06:39 PM
CSIPSD's Avatar
PHP Hydra with Isspro EV-2 gauges...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #5 of 12 Old 10-18-2013, 10:09 AM
Justin@DP-Tuner's Avatar
Quoted: 54 Post(s)
As long as all of the sending units are in good working order, the readings are very accurate. I used to run a set of pillar gauges before I ran the Infinity and have compared them against each other. The boost numbers were almost spot on(less than 1psi variance), and trans temp was very close as well(less than 10* difference at all times). The trans temp will usually read a tad hotter through the OBDII port because the fluid temp is taken from a sender inside the solenoid body. Fluid temperature in the test port or pan is a little bit cooler.
You can also add additional inputs/sensors to the Infinity as well, which will enable you to monitor parameters that are not seen by the PCM.
If you have any questions about the Infinity or its features, don't hesitate to ask. I would be happy to help you out.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #6 of 12 Old 10-18-2013, 10:17 AM Thread Starter
mksnipe's Avatar
Awesome I was just looking you up. I was looking into a setup like Kris(351fifty) and was curious what I needed to buy.
1995 F350 CCLB
TS6 chip
Custom intake
E - fuel
FUTURE
upgrade HPOP
D66
Intercooler
done?...for now
mksnipe is offline
post #7 of 12 Old 10-18-2013, 02:26 PM
I'm currently running a TS 6 pos in my truck along with the Edge CS for my gauges and I am pretty happy with this set up. I kept going back and forth between analog gauges and the CS but I'm happy with my Decision.
PDRdiesel_matt is offline
post #8 of 12 Old 10-18-2013, 05:20 PM Thread Starter
mksnipe's Avatar
I've been eyeballing the cts as well it is a tough choice but I like the features the infinity offers. But I'm with you I think the monitor is the way to go just cleaner looking with more info and i am going with a ts chip.
1995 F350 CCLB
TS6 chip
Custom intake
E - fuel
FUTURE
upgrade HPOP
D66
Intercooler
done?...for now
mksnipe is offline
post #9 of 12 Old 10-18-2013, 06:20 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
I have a CTS and Gauges along with a ts 6 postion. Its a great setup to keep an eye on everything. Gotta remember the PCM doesnt monitor everything on our trucks so the analog gauges catch up the difference (egt, accurate trans temp, boost).
Trucks and parts............
kanuck15 is offline
post #10 of 12 Old 10-19-2013, 07:08 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Only thing extra I had to get for my infinity to monitor is egt, I love it, also works on my other fords so I'm happy
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
