New to the obs diesel - Ford Powerstroke Diesel Forum
post #1 of 29 Old 10-15-2013, 06:34 AM Thread Starter
gearhead11's Avatar
Im new to the diesel game. Ive always wanted one, but it just never worked out til now. I bought a 1995 F250 supercab 4x4. it had 295,xxx miles on it when i bought it. Ill be using it as a DD and occasional tow rig for my offroad truck. Ive already done the muffler and cat delete on it using just some pipe from the local muffler shop. I also removed the air box and put the biggest spectre air filter i could find. Those two mods made a huge difference in the performance of the truck.Truck was all stock when i got it.
Are there any problems that I should be aware of with that truck?
gearhead11 is offline
post #2 of 29 Old 10-15-2013, 07:40 AM
Arcturus's Avatar
The donaldson B085011, I believe has much more air capacity than a spectre that is oiled? No need for the oil as it restricts airflow and the goal is to get as much air flow as is possible.
B085011 - 6637 - ECB DONALDSON REPLACEMENT FOR NAPA 6637 - Filter Products
As for problems mainly the fuel bowl, the fuel lift pump, injector orings and UVCH connections seem to be the biggest problem topics here.
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Last edited by Arcturus; 10-15-2013 at 09:13 AM. Reason: booboo on oil lift pump? lol
Arcturus is offline
post #3 of 29 Old 10-15-2013, 08:09 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
First 4 thing you should do to any 7.3 in this order should be Gauges(egt, boost, and trans temp if automatic), intake(donaldson filter at the link provided above), straight pipe exhaust(new downpipe at the very minimum because stock downpipe is flat and really restricts flow), lastly a chip(at the least a good economy tune, race tune, and tow tune)
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #4 of 29 Old 10-15-2013, 09:08 AM
Quoted: 44 Post(s)
^^^^^ Those are the biggest _engine_ problems (and it's the fuel pump that's typically more problematic than either oil pump). The biggest problem related to the truck, if so equipped, is the automatic transmission. If it's a manual, by now it's probably had the clutch replaced and hopefully the dual-mass flywheel replaced with a single-mass.
Also look carefully for rust, esp. on the radiator core support and the spring/shock hangers. The Dana 50 TTB front end is a PITA to align and likes to eat tires - rotate frequently. "Real" fix is to swap for a Dana 60 straight axle ("virtual F350"). Steering is the same as the gassers, therefore a bit underengineered. Just watch the threads in the General and Problems sections to get a better feel of what else to watch for.
madpogue is offline
post #5 of 29 Old 10-15-2013, 09:15 AM
Arcturus's Avatar
Originally Posted by madpogue View Post
^^^^^ Those are the biggest _engine_ problems (and it's the fuel pump that's typically more problematic than either oil pump). .
I fixed my post. oil lift pump? What the heck is that? lol
JackT
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #6 of 29 Old 10-15-2013, 09:18 AM
Chapter Director
Quoted: 5 Post(s)
Low pressure oil pump(LPOP)
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 29 Old 10-15-2013, 09:27 AM
Quoted: 44 Post(s)
That would be better described as the oil _lube_ pump, since that's its primary purpose.
madpogue is offline
post #8 of 29 Old 10-15-2013, 09:37 AM
Chapter Director
Quoted: 5 Post(s)
But its better NAMED the LPOP
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #9 of 29 Old 10-15-2013, 10:54 AM Thread Starter
gearhead11's Avatar
Thanks everybody. I was told by the PO that the trannie had been rebuilt at about 240,000 miles, and Im not hard on a vehicle anyway. A farmer friend of mine told me that if it had 4.10 gears then I would be changing trans every 2 years. I should be ok, ive got 3.55's. The air filter will get upgraded latter on, thats all I could find in town. As will the exhaust. A chip is also in the plans, as are gauges. As far as the TTB, Im more than familiar with that. iI wheeled an 89 ranger with that for about 4 years. finally upgraded to 1 ton running gear. The truck was owned by a company that sells and services forklifts, so the maintenance was done fairly regularly. Im excited about owning this truck, I hope even with the amount of miles that are on this truck that ill still be able to drive it for a long time. Im sure this wont be the last time Ill have questions.
post #10 of 29 Old 10-15-2013, 09:11 PM
sethc24's Avatar
get a 3" downpipe on it. Total diesel performance sells awesome tuning.
1997 F-250 4x4. 5 speed
, 6637,exhaust,dp-tuner,dana 60, 33's
sethc24 is offline
