diy injectors? - Ford Powerstroke Diesel Forum
Old 07-10-2008, 11:52 AM
diy injectors?
so i see diy injectors alot on here and thinking about doing it. is it worh it? stage one is only 250$ and is 160cc but the stage 2 is like almost $800 f 160cc to. whats the deal? is diyworth it?
Old 07-10-2008, 12:08 PM
Jim with DIY is great to deal with.
His kits are very much worth it
Old 07-10-2008, 06:30 PM
is the stage one good enough?
Old 07-10-2008, 06:39 PM
Good enough for what? what are your goals out of them?
It is all about your HP goals!
Old 07-10-2008, 06:59 PM
i just want to get my chip to give its full power, just the stage 1 is 160cc and $260 and the stage 2 is 160cc but $800 so whats te diff, i dnt want insane power just alot of black smoke. and its a manual with a single mass cluch will thathold up?
Old 07-10-2008, 07:41 PM
Add big injectors and your clutch will probably be TOAST.
If you are worried about that, than just do the stage ones
Old 07-10-2008, 09:11 PM
Electrical Ogre
The stage 2's can dump more fuel with the larger nozzle holes. On Tony's "stock" setting I can even get 'er smokin' You just need to consider how high your power goals will be, and will your old nozzles with xx miles on them still be good, or replace them with new stock ones for a better quality rebuild job.
Old 07-13-2008, 05:37 AM
We need more info about your truck to really help you out.
Stage-1's are a great upgrade for the '94 - '97 trucks. It really wakes them up with a good custom chip.
Stage-2's are basically the same injector, but have new larger nozzles. The Stage-2 Kits start at $725, not $800...
Stage-1's are pretty much maxing out the capabilites of your stock fuel system, turbo, etc, and will stress out your trans/clutch if you run an extreme burn all the time.
Stage-2's are much harder on the same stuff.
If you plan to upgrade these things over time you can tune down the injectors for now, then reburn your chip later to take full advantage of the Stage-2's.
Old 07-13-2008, 06:41 AM
Feedback Score: 5 reviews
If you want smoke you don't need inj. Have TW burn you a smoke tune. Getting inj. takes a commitment and $$ to mod all the other things that you need to install with them.
Cary
Old 07-13-2008, 12:21 PM
ya i think im over the injectors, cause im doing wvo system for it so i dont want to mess with the injectors, ill just do a chip for now
