Another D66 Turbo Queston - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-12-2013, 12:09 PM Thread Starter
I'm not trying question Beans for adapting a stock turbo to something distinctly better but what changes are actually being made to the stock turbo to where it becomes the D66?
A different wheel, yes
Porting?
More? I don't know...
Curious if anyone knew the specifics and was willing to share.
Thanks
1995 f-350, 108,000 miles and climbing, second motor with approximately 130,000 miles on it.
DIY Intake, stage 2 injectors from Rosewood, 3" DP to 5"side dump with a 6" Tip
HPOP, 6.0 IC (anyone have a spyder?) and E fuel to come
wakeboardin2k4 is offline
post #2 of 8 Old 10-12-2013, 09:52 PM
Spud Monkey's Avatar
Would guess the 66 part means 66mm compressor wheel inducer compared to factory compressor wheel inducer diameter of 59.87 mm (60 mm) to accommodate the larger wheel plus going from 80mm compressor wheel exducer diameter to 91mm.
Spud Monkey is offline
post #3 of 8 Old 10-13-2013, 08:16 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Machined cover to fit, they come with the 1.15 exhaust housing in the super duties, and I'm sure they come with that same housing for the obs. It's a ton more air than a stocker. And he's right about the wheels being totally different
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #4 of 8 Old 10-13-2013, 08:56 AM
c69ss396's Avatar
The only issue alot of us with stock sticks or stage1's is high egt's because the D66 turbo spools up at a way higher rpm, We have over came that by swapping out their 1.15 housing with a 1.0 housing. We all Have the same boost numbers but get it sooner to cool things down and clean things up.
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #5 of 8 Old 10-13-2013, 06:06 PM Thread Starter
I have rosewood stage 2s with a conservative tune and a stock turbo. I am looking to improve the amount of air being produced by the turbo. I continue to look at the new WW2 and the d66. Just trying to figure out the correct route without blowing unnecessary money.
post #6 of 8 Old 10-14-2013, 07:06 AM
Doesn't Even Care
Quoted: 69 Post(s)
Id go with the bigger turbo. You're not getting the most out off your setup with a stocker and conservative tuning
Nick
"The Mistress"
post #7 of 8 Old 11-19-2013, 06:57 AM
97bluepowerstroke's Avatar
I love my d66.. and the new ones have a new billit wheel that they got another 20hp out of on the dyno... im switxhin wheels soon on mine
97 f250hd 4x4 7.3l. TW 6 pos, Rosewood Stage 1 Injectors, gauges, DIY intake, 3in dp ti 5in exhaust, D66 turbo.. More to come
97bluepowerstroke is offline
post #8 of 8 Old 11-19-2013, 02:56 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
i went this way for 15K miles. i have gone to a D66, WW2 and 1.0 housing. it's night and day difference
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
